changed fuel filter, won't start
Old Sep 21, 2009 | 06:54 PM
Silver R/T's Avatar
changed fuel filter, won't start SOLVED
followed instructions on this site http://wiki.dieseltruckresource.com/..._Filter_Change
Bumped starter a few times, started it, it ran for 5-10 seconds and quit. I've bumped it a few more times, made sure there's fuel in canister (I opened valve and it came out at good pressure) Bumped it some more and it won't start.
I wish changing fuel filter was easier than this, this is frustrating.
Old Sep 21, 2009 | 07:09 PM
rebal's Avatar
You should do it 2-3 time to purge the air you might need to open 3 injector lines ,have a helper crank on it as you close the injector lines one at a time as it starts , I usually open the 3 easyest
Old Sep 21, 2009 | 07:53 PM
Silver R/T's Avatar
Thanks, truck runs now!
Old Sep 22, 2009 | 06:56 AM
Ronny Bailey's Avatar
Good news! Did you have to open the injector lines?
I always fill the filter with fuel before installing it. Never had any starting problems.
Old Sep 22, 2009 | 11:24 AM
Silver R/T's Avatar
opened couple of injector lines until it started squirting out
Old Sep 26, 2009 | 05:05 PM
BigIron70's Avatar
Cummins Guru
Sounds like your transfer pump is going out. Min fuel vol is 45OZ @ 25 sec. If below this amount replace the pump.
mattzram
Oct 9, 2006 11:38 AM
mattzram
Oct 1, 2006 07:01 PM
fitzydog
Apr 21, 2005 09:04 PM
dominojd
Jun 21, 2003 01:24 AM
99purplecummins
Dec 7, 2002 10:38 AM
