changed fuel filter and won't start
Old Dec 4, 2002 | 10:12 PM
99 cummins's Avatar
Re:changed fuel filter and won't start
I put about 600 miles on this dead lift pump. The truck ran fine other than fuel mileage sucks and it had no power.
Old Dec 4, 2002 | 10:18 PM
Dieseldude4x4's Avatar
Can we assume that you bumped the key and bled the system several times prior to trying to start it?
Old Dec 4, 2002 | 10:54 PM
tool's Avatar
Wouldn't running the truck with a dead lift pump and no pressure be very bad for the injection pump??<br><br>Or am I wrong? ???
Old Dec 5, 2002 | 07:51 AM
99 cummins's Avatar
I finally got the truck started by putting a bleeder pump on an outgoing line of the injector pump and just sucking the fuel through the lines. I'm sure it's not how it was supposed to be done, but as I said before I'm a pretty fair tinkerer, but I suck as a mechanic. The injection pump wear and tear was my biggest fear, but we were waiting on a back-ordered part and this was my only transport.
Old Dec 7, 2002 | 10:38 AM
diesel dave c's Avatar
Hi guys. I know this is to late to help you, but other people might make use of this info. I read on another site that the lift pump on 98.5-2001 trucks is a carter pump that can be found at napa or other suppliers a lot cheaper. This post also stated that these pumps are for small distance lifts and are being used on cummmins outside these lift distances and that you will have to keep replacing them.<br>Has anybody thought of mounting an inline holley pump back at the tank andusing good braided line and aeroquip fittings to beef up the fuel delivery. They use this system on drag cars, so volume and pushing power should be quite high. I know Holley is mostly a &quot;GAS&quot; parts supplier, butthey should have stuff available for diesel. If not, maybe some demand will change that<br><br>Dave
Silver R/T
Sep 26, 2009 05:05 PM
mattzram
Oct 9, 2006 11:38 AM
mattzram
Oct 1, 2006 07:01 PM
fitzydog
Apr 21, 2005 09:04 PM
dominojd
Jun 21, 2003 01:24 AM
