Boost guage install HELP!!!!
Old Apr 12, 2003 | 12:56 AM
snow104's Avatar
2001 2500 4x4<br>BD guages. <br>They came with a fitting to hook up the boost to the eng.<br>But it doesn't tell me where or how ???<br>Guessing it goes in the intake someware, But I guess I'm just to stupid to figgure it out <br>At this point I could really use a picture :
Old Apr 12, 2003 | 08:28 AM
Smokee's Avatar
Re:Boost guage install HELP!!!!
There is a plug on the intake that you remove and replace with your new fitting. On the 12V, the fitting is just below and behind the airhorn.<br>The alternative is to drill and tap the air horn.<br>george
Old Apr 12, 2003 | 09:11 AM
scottrod's Avatar
On the drivers side of the block there are two plugs directly behind the fuel filter housing. The one closest to the filter housing is the one to remove. You'll need a bushing to step down from 3/4 to your fittings that came with the gauge. <br>
Old Apr 17, 2003 | 03:05 PM
TPilaske's Avatar
Check out the bottom of this page to see how/where to install the boost line into the test port:
http://www.showmestate.org/stltdr/how-tos/EGT_how_to.shtml
JAX
Aug 31, 2006 04:19 PM
mxdsl183
Feb 23, 2006 03:10 PM
bigragu
Jan 24, 2006 11:16 AM
marv h.
Dec 28, 2004 01:15 PM
soundfetish
Feb 26, 2003 03:35 PM
