4hrs from home truck missing codes p0205 and p0607. Help!!!
Old Sep 15, 2012 | 10:31 AM
tacdaddy's Avatar
Hi guys, need your help. I'm on the road 4 hrs from home. Truck started missing bad and lots of heavy vibration. Ran the codes. Showing p0205 and p607. I have limited resources today, out in BFE. I'm typing all this from my iPhone.
First: any idea on what is going in and a quick fix?
Second: if I can't get it fixed, is it ok to drive it on home.
Thkx in advance on this one. Truck specs are in my sig.
Old Sep 15, 2012 | 03:26 PM
tacdaddy's Avatar
Just replaced both bat. Still runs rough. Still shows codes. Checking inj plugs that go into valve cover.
Any other ideas? Come on guys I really need help on this one
Old Sep 15, 2012 | 04:33 PM
firestorm's Avatar
Here's what I've found
A P0607 could be caused by one or more of the following:
Loose ground terminal on PCM/ECM
Dead or defective (12V main) battery
An open or short in the power or ground circuit
Loose or corroded battery terminals
Failed PCM/ECM
Sent from my iPhone using Tapatalk
Old Sep 15, 2012 | 04:35 PM
firestorm's Avatar
The P0205 refers to the #5 injector circuit. I'm also doing this from my iPhone.
Old Sep 15, 2012 | 04:44 PM
tacdaddy's Avatar
From what I have read p0607 is being triggered from the p0205. I just greased the valve cover connections for injector #5. I set the timing on the XRT Pro to default. It was at one step up from the XRT default. Still running rough and showing codes.
What to do????
Old Sep 15, 2012 | 06:55 PM
tacdaddy's Avatar
Ive come to the conclusion that im not going to fix it where i am. I really need to know if it safe to go ahead and drive the truck the way it is. It idles rough. At min acceleration it's rough. It's pretty smooth on heavy acceleration. The main thing is that I don't want to hurt the motor by driving on it.
Old Sep 15, 2012 | 08:00 PM
kthiemann's Avatar
Where are you at?
Old Sep 15, 2012 | 08:04 PM
j_martin's Avatar
It's a deisel. If a cylinder isn't getting fuel, it's just dragged along for the ride. Runs cold, might use a little oil.
When's the last time you heard an Amtrak engine hitting on all cylinders?
I would keep sniffing, have the battery disconnect wrench and a fire extinguisher handy, though.
Old Sep 15, 2012 | 08:38 PM
roughstock's Avatar
Bad injector harness? common problem.
Old Sep 15, 2012 | 08:47 PM
tacdaddy's Avatar
Originally Posted by kthiemann
Where are you at?
I just made it into FTWorth. Should be able to find a dodge/cummins mech wanting to do some side work on the weekend here.
Old Sep 15, 2012 | 08:49 PM
tacdaddy's Avatar
Thanks for the input. Good point on Amtrak. Lol I just didn't want to tear up anything running that cylinder dry
Old Sep 15, 2012 | 08:57 PM
tacdaddy's Avatar
I narrowed it down to with the injector or the harness inside the valve cover. I hope it's the harness. I was thinking if I have to replace an injector I might as well put in 50hp all around. This way I could sneak it by the wife. Lol
Old Sep 15, 2012 | 09:02 PM
Totallyrad's Avatar
If possible, remove any programmer and get the truck back to stock. If you've got an injector going down, drive the bare minimum. It's very easy to melt down a piston and take out some valves.
Old Sep 15, 2012 | 10:09 PM
kthiemann's Avatar
Glad you made it into town.
Old Sep 16, 2012 | 09:53 PM
tacdaddy's Avatar
Ok guys, I pulled the valve cover and checked the wires. The looked ok. Put the meter on the #5 injector with the injector disconnected. Ohm showed 0. Bad injector it is. Just got everything back together. I'm dropping it off at the dealer or maybe cummins in the morning. Thanks for all the input. This forum has saved my butt several times.
donhov
Jun 6, 2012 06:35 PM
UnrulyNFS
Apr 10, 2008 11:04 PM
UnrulyNFS
Apr 10, 2008 10:57 PM
jwb600
Oct 13, 2007 04:15 PM
