P0205 injector #5 control circuit???
My brother is on the road and has gotten this code under acceleration. Anybody seen this or heard of this before. He's checking his harness connections.
Was just hoping for some more info.
Cummins Guru
Hope this helps,
Disconnect the pigtail nuts from the suspect injector. Using an Ohmmeter, measure the resistance between the solenoid posts of the injector.
NOTE: Be sure to zero the ohm meter prior to checking the injector circuit.
Is the resistance less than 1 ohm and greater than 0 ohms?
No
Replace the fuel injector
No
moparmatt
May 15, 2011 12:03 PM
97dodgeram2500
Jan 19, 2010 03:41 PM
Joe Diesel
Nov 12, 2007 08:59 AM
