injector experts-P0205 code?
Old Oct 13, 2007 | 09:39 AM
jwb600's Avatar
I got a po205 code on my truck. I pulled it up with the smarty. the description was Injector number 5 control circuit. the truck ran rough on the way to work. no white or gray smoke but I think im going to haul it back home tomorrow just to be safe. now the question I have is the wiring bad going to the injector or is the injector bad? thanks for any input in advance
Old Oct 13, 2007 | 10:39 AM
jwb600's Avatar
noone has had this same code?
Old Oct 13, 2007 | 10:41 AM
dodgezilla04's Avatar
have you removed the valve cover, installed different injectors, or removed the injector wires(at the injectors) before?
i have seen the wire lugs rotate and just touch the rocker arm, shorting out causing rough running and that code.
Old Oct 13, 2007 | 11:17 AM
Rpainter's Avatar
or the solenoid could be going bad and throw that code
Old Oct 13, 2007 | 11:28 AM
bob4x4's Avatar
Swapping the injector with another hole will tell you what you need to know.
Bob
Old Oct 13, 2007 | 04:15 PM
jwb600's Avatar
yes sir. we have had the valve cover off a couple times here lately. I am hoping it is not an injector. thank you for the info
tacdaddy
Sep 16, 2012 09:53 PM
donhov
Jun 6, 2012 06:35 PM
UnrulyNFS
Apr 10, 2008 11:04 PM
UnrulyNFS
Apr 10, 2008 10:57 PM
