2004 just died
Old Apr 4, 2009 | 11:05 AM
West Coast's Avatar
2004 just died
I was with my buddy and his 2004 just died. Truck started about 30 minutes later and ran for about 20 more minutes and died again. Got the truck back home and let it sit for about 2 hours. He started up the truck and was letting it idle and it died again.
I own a 94 dodge so I am unfamiliar with the code reading on the dash. So I am going to do a search right now for that procedure. Truck seems to be shut off because lack of fuel. Lift pump of injection pump???
Thanks.....
Old Apr 4, 2009 | 11:20 AM
West Coast's Avatar
Codes
P0633 SKIM Secret Key Not Entered
P0628 Low Voltage Detected At The Fuel Lift Pump Relay
P0602 Checksum Error
So what do these codes mean?
Old Apr 4, 2009 | 12:20 PM
huntman509's Avatar
does it have an updated lift pump? if not it will be mounted on the fuel filter housing, you can try tapping on it with a hammer lightly, i dont think you can still buy this style pump, due to the update and failure rate of that pump
Old Apr 4, 2009 | 12:31 PM
annabelle's Avatar
Sounds like a lift pump.
Old Apr 4, 2009 | 01:02 PM
West Coast's Avatar
Is the lift pump recall issue?
Sounds like he should not drive the truck. Good chance if it is the lift pump it could take the injection pump with it......
Thanks for the replies.....
Old Apr 4, 2009 | 01:09 PM
West Coast's Avatar
What after market lift pump would be a good choice? We need to get the truck running by Sunday. We might be able to get an after market lift pump at our local Summit Racing......
Old Apr 4, 2009 | 01:33 PM
huntman509's Avatar
no i dont think its a recall thing, i dont think there is a aftermarket replacement for those, i have been getting them from the dealer, the new one goes in the tank
Old Apr 4, 2009 | 02:16 PM
annabelle's Avatar
Not a recall issue.......you can go FASS or Airdog or a number of better than OME after market pumps.
Old Apr 4, 2009 | 03:29 PM
JP-4.5's Avatar
Glacier Diesel kits and add the 2 micron filter while you are at it..
Old Apr 4, 2009 | 06:43 PM
rich's Avatar
i ran holley blue on my 03 and no these injection pumps wont die without lp they just dont run at all
MrMoparMan
Apr 23, 2010 09:17 PM
tomm
14
Dec 25, 2006 10:26 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
