Sponsored by:
Sponsored by: CARiD
Lift pump?
Old Dec 23, 2002 | 07:06 PM
deere nut's Avatar
Lift pump?
I'm a new cummins owner ;D so bear with me. What is a lift pump andwhere is it? I know it's some sort of fuel pump that everyone says goes out prematurely and is a headache. What sort of pressures would indicate it is going out?<br><br><br>
Old Dec 23, 2002 | 07:14 PM
Hired Gun's Avatar
Re:Lift pump?
well from my understanding, it is right outside the fuel tank on the rail. Pressure. Well if you have a fuel pressure gauge you will see that at idle it can vary from 13psi to 18. At wot it shouldnt dip below 5 I think. Someone else will put you straight, but this gives you an idea. If you dont have a gauge, then get one fast. Friendly advice.
Old Dec 23, 2002 | 07:38 PM
DarrellB's Avatar
Re:Lift pump?
Well, how educated do you want to get? You can do a search and you'll have about 4 days of reading on the subject of lift pumps. : :'(<br><br>I can tell you were it is located. It's sits on the drivers side of the engine block right under and to the right of the fuel filter. You can take the inlet fuel line to the fuel filter and trace it down to the lift/transfer pump. Fuel pressure should be 13psi to 18psi at idle and at WOT (wide open throttle) should drop no lower than 8psi. If it's lower than 8psi you need a new lift pump.<br><br>If you would like a good test gauge you can get one here. Black Mountain Diesel The gauge is called the Briar Hopper test gauge and works great to test your fuel pressure if you don't want to mount a permanet gauge. <br><br>DB
Old Dec 23, 2002 | 08:07 PM
phox_mulder's Avatar
Re:Lift pump?
Didn't they move it for the 2003's?<br><br>phox
Old Dec 23, 2002 | 08:34 PM
deere nut's Avatar
Re:Lift pump?
Well if its bound to go out on the 03's like they have in the past I guess I should upgrade. Sounds like its a simple bolt on job. Expensive? Should I wait?
Old Dec 23, 2002 | 08:49 PM
DarrellB's Avatar
Re:Lift pump?
[quote author=phox_mulder link=board=8;threadid=8730;start=0#84242 date=1040695671]<br>Didn't they move it for the 2003's?<br><br>phox<br>[/quote]<br><br>Ha, I didn't even notice he had one of them purtty new trucks. <br><br>DB
Old Dec 24, 2002 | 10:58 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Lift pump?
Yep, the 03's have changed the pump location and type. Its bolted right on the side of the fuel filter canister now and will deliver 9.5 PSI at idle (at the injection pump. 11.5 at the lift pump according to the FSM), 8.5 at cruise, and 5 at WOT. As far as I know, there are no lift pump upgrades available as of yet, but it won't take much to switch the system over to a Holley (or other) remote mount transfer pump.<br><br>Rod
Old Dec 25, 2002 | 09:09 PM
Stamey's Avatar
Re:Lift pump?
Push Rod,<br>Is it still a Carter, like the older ones? Have you heard anything about the reliability of it? Or will we need to have a source inside DC to find out early if these pumps are any better than the last ones?<br>I still can't believe the mounting location they chose. Maybe that's so people will associate with the engine instead of the body when it fails? (Just pullin BS out of my keyster at this point.)<br><br>Chris<br>
Old Dec 25, 2002 | 09:20 PM
Push Rod's Avatar
Re:Lift pump?
[quote author=Stamey link=board=8;threadid=8730;start=0#84839 date=1040872167]<br>Push Rod,<br>Is it still a Carter, like the older ones? Have you heard anything about the reliability of it? Or will we need to have a source inside DC to find out early if these pumps are any better than the last ones?<br>[/quote]<br><br>I haven't found a tag on mine yet, but I haven't looked at it all that hard. I have my suspicions that its a Carter. And from talking to the boys at TST, I'm going to say that its less reliable than the old lift pump, at least with BOMBed trucks. My local Dodge mech will keep me up to date on stock trucks.<br><br>Rod
Old Dec 25, 2002 | 09:41 PM
deere nut's Avatar
Re:Lift pump?
If a holley black 160gph is used to bypass the stock pump, should the banjo bolts also be ugraded? i plan on getting and edge ez when it comes out. How long do these holley pumps last?<br>
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
