Sponsored by:
Sponsored by: CARiD
Diesel Replacement?
Old Jul 28, 2008 | 09:30 AM
buldaawg's Avatar
Diesel Replacement?
http://www.pickuptrucks.com/html/sto...diesels-1.html
Old Jul 28, 2008 | 11:40 AM
MikeyB's Avatar
I see way to many holes in that article. I cannot see a 5.0 putting out 500hp/700tq without some serious modifications for longivity. With the mods needed the price delta between that and a diesel will probably be nil.
Then there's less BTU's with gasoline and ethanol. So the effeciency is still not quite there.
And I hate the thought of needing two fuels.
MikeyB
Old Jul 28, 2008 | 12:32 PM
DBLR's Avatar
They can't make enough ethanol now for cars to use so where are they going to get enough ethanol to keep all of these semi trucks using this engine running?
Old Jul 28, 2008 | 03:41 PM
stinkindiesel's Avatar
I liked the diesel truck's "brutish torque" part.
Old Jul 28, 2008 | 09:33 PM
dkenny's Avatar
they really need to learn math....
if the diesel pick get better mileage... ok for comparsion, but a small sample
my 2000doge ram gas get 14 MPG. gas $4/gallon.
my 99dodge ram diesel get 21MPG..diesel 4.70 gallon
21MPG over 14 MPg is a %50 increase...for 0.70 cents per gallon..
diesel doesn't cost %50 percent more!!
500 HP out of a 5 L..might be possbile GM get 120HP/L using direct injection fo gas but their diagram isn't direct injection..so I'm skeptical..
I'll stay with diesels and biodiesel..
-dkenny
Old Jul 29, 2008 | 01:12 PM
Diesel_Storm's Avatar
MikeyB
Or 2 injectors per cylinder. That would be expensive.
Old Jul 29, 2008 | 07:32 PM
brianpgriset's Avatar
Ethanol? What a joke. I can't wait for the whole ethanol thing to die. I mean what a waste of perfectly good natural resources. Some people NEVER think things out.
Old Jul 29, 2008 | 10:22 PM
dj_souvlaki's Avatar
i've said it before and i'll say it again
your running alcohol = higher heat = stressed and blown engine
ethanol and methanols both attract wayyy too much water and do not mix with water just seperate. they have a short shortage life and are useless.
Old Jul 29, 2008 | 10:53 PM
dkenny's Avatar
i've heard the alcohol fuels are cool burning..not hot.. they both have higher octane ratings than gasoline. around 110 instead of 87-93.
ethanol and methanol do not separate with water..its only when gasoline is added that there is a problem. and don't add fiberglass( I don't if epoxy or vinyl esters are the problem). I would suspect vinyl esters.
-dkenny
just the same I'll stick with diesel or better biodiesel
Old Jul 30, 2008 | 01:13 AM
Tate's Avatar
$1500 extra for this set up? More complex ECU, extra fuel tank, injectors, fuel system, sensors. Then you actually need to make this engine survive at 700 lb-ft (forget the 500 hp, that will be all RPM). Stronger rods, bottom end. Needs to be made to commercial standards atleast, not just automotive if this is the replacement for the diesel engines. The retail price difference only $1500, but the production costs difference will be greater.
I'd be happy to watch Ford's experiment from the sidelines. Be one more nail in their coffin.
74dart
Jan 31, 2010 09:27 AM
smokinram99
Mar 24, 2008 07:22 PM
dj_souvlaki
Nov 8, 2007 12:04 PM
sliqwille04
15
Oct 29, 2007 10:52 PM
Roger Lee
Jun 9, 2003 12:10 PM
