77 Dodge Ramcharger 4bt conversion.
Old Jul 10, 2018 | 01:54 PM
  #46
Originally Posted by J10Mike
Took a long road trip in the RC over this weekend. Finally, some real hand calculated MPG numbers using GPS speedometer/tripometer. 90% highway doing 65 to 70 MPH.
4bt, 46rh, 4.10s, on 35s. 19.25 MPG.
I was hoping for at least 20 MPG. But, close enough. Maybe had I had 3.54 gearing. Oh well.
At least it's better than the 9 MPG I was getting with the old 360.
I have gotten 22.1 IIRC as my best tank on my '89 RC with a 12V Getrag 4x4 set up with 3.54 gears in the D60 + D70s
I would guess the gearing is hurting you the most.
Old Jul 10, 2018 | 02:09 PM
  #47
J10Mike's Avatar
Ya, that's what I was thinking. Close enough though. I'm not complaining.
Old Apr 24, 2020 | 09:30 AM
  #48
J.Jacob's Avatar
More pics...
What will be the boost pressure?
Old Apr 24, 2020 | 11:03 AM
  #49
J10Mike's Avatar
Best I've seen so far is 23 PSI.
Old Oct 7, 2021 | 08:46 PM
  #50
J10Mike's Avatar
77 Ramcharger, 4bt build. Intercooler installed...
Hey Guys, It's been awhile...
Intercooler install, Part 1, completed. This factory I/C is out of a 92 Dodge that I picked up from a local guy (Stretch) a couple few years back. An old guy at local radiator shop leak tested it and painted it for me over the Summer. I put the drill and sawzall to use to cut rectangular holes into the core support. It was that, or try to locate a 91.5 thru 93 I/C core support. Which, are few and far between.
Anyway, it had plenty of room behind the grill and install came out better than I expected. Pics below.
Up next, Part 2. Installation of new intake manifold, intake horn, clock the turbo, and run the pipe.
Old Oct 24, 2021 | 06:34 PM
  #51
J10Mike's Avatar
Intercooler finished.
All finished. Installed new intake manifold plate and ran the pipes to the intercooler. Big difference in EGT's. Took the RC up a steep hill that would push EGT's to about 1400 degrees before intercooler. Now with intercooler, same steep hill it may have hit 1000 degrees. It was between 950 and 1000. So, much happier about the decrease in EGT's. Before intercooler, my boost would max out at 23 PSI. Now, boost max is 20 PSI. I didn't notice an increase in performance, I was watching the gauges. What I did notice is that is took longer for engine/water temp to heat up. And, it was a warm day today. Maybe due to cooler intake air being pushed? In any case, pretty happy with the intercooler installation.
A couple pics attached.
Turbo side.
Intake side.
Old Oct 26, 2021 | 12:10 PM
  #52
Glad to see you still tweaking the RC.
Looks like it was well worth the effort to make it intercooled, as that is a serious temp drop in EGTs!
Old Oct 26, 2021 | 07:19 PM
  #53
J10Mike's Avatar
Serious temp drop is right. Did a couple double takes to make sure I was reading the Pyro right. Always tweaking the RC. Just when I think I'm finished, some other upgrade pops up in my head.
208soarer
Jun 30, 2017 04:31 PM
Jer12377
Oct 14, 2013 04:01 PM
Jreif80
Jun 27, 2007 01:09 PM
cowboy717
Feb 22, 2006 12:58 PM
rush47
Nov 2, 2005 09:59 AM
