1997 Chevy K3500 CC DRW 454 to 12 valve
Old Dec 7, 2009 | 11:45 PM
  #91
Twisted Inc.'s Avatar
i wish destroked made mounts to work in my 87 chevy cummins swap, i wonder how those mounts are going to work with the ford chassis? is any extra fab. going to be required?
Old Dec 7, 2009 | 11:53 PM
  #92
1-5-3-6-2-4's Avatar
nope they are pretty bolt in. i line it up forward/backward exactly where I want it and I sink the bolts through. done deal.
well the new of the company is deSTROKED so i can see them not making chevy mounts. I put a cummins on a ford frame where there used to be a powerstroke engine. the Destroked mounts were designed for exactly this. I'm just putting a chevy body on a destroked Ford F450. sort of.
but theres 2 outfits that DO make cummins chevy conversion mounts and cross member for the older chevy trucks.
Scott at Tennessee Diesel Conversions makes kit. and Avalanche engineering makes a bolt in crossmember/mount kit.
Old Dec 8, 2009 | 12:17 AM
  #93
pind's Avatar
So basically, you are defording a destroked conversion by dressing it up with a bow-tie.
Good job overall, I like what you're doing. Pretty much building everything that a ford isn't. Good engine, comfortable body, and still the backbone of a real work truck.
If I had the time, it would be great to do the same things, although I am too busy keeping everyone else' world working properly. That said, I have a short term plan for a turbo on my 1990 toyota pickup with a stock 22r. And I also have a 93 GM ex-cab dually, with a 6.5 that is getting a new tranny, and a 8x9' dump deck, and probably a straight axle, for use as a wood truck.
Keep up the good work, and the updates.
Old Dec 8, 2009 | 12:35 AM
  #94
yes that about sums it up.
I've gutted the interior too of all the blue. I have a full black leather interior waiting to go in.
Old Dec 8, 2009 | 09:56 AM
  #95
yeah, that kinda slipped my mind that the chassis you are using was originally i powerstroke!......but destroked does make motor mounts for a 88-00 chevy i believe.....awesome build man!
Old Feb 14, 2010 | 01:28 AM
  #96
okor's Avatar
Any updates? I have a 94 chev extended crew cab that's getting a 12v BT6 in the next couple weeks. Mine is also getting a 6" suspension lift so I'll probably be able to drop my motor pretty deep to get the weight lower.
Old Feb 16, 2010 | 12:48 PM
  #97
jesussaves's Avatar
is there a company like destroked or fordcummins for GMC's?
Old Feb 16, 2010 | 09:13 PM
  #98
are you solid axle swapping the '94? or IFS lift?
either way it is restricted to your engine crossmember. doesnt make any difference to lower your engine really, you're putting a 1200lb engine into a 7000lb truck. whats a couple inches really getting you.
theres a couple places that make mounts and crossmember for GMs. Tennesse diesel conversions is where I got my original mounts for the '97 Gm 3500 chassis. Scott is a goodfella there.
Old Feb 16, 2010 | 11:56 PM
  #99
okor's Avatar
I'm keeping the ifs. I haven't had any problems with it so far and I'm getting old. I like the cumfee ride. I want to drop the engine as far as I can just for the lower C of G. I know it'll not be much, but I'm not putting on huge tires or anything crazzy. I'm just building a nice simple reliable tow rig.
I'm a steel fabricator so fabbing the mounts won't be a problem. And mine won't be 7000lbs. I'm hoping to keep it under 8,000 but will probably be in the 9,000 range by the time all is done.
Old Feb 17, 2010 | 08:19 PM
  #100
your ifs brackets will be in the way. and the brackets are integral with the engine crossmember. as will the torsion bar crossmember be in the way of the Tcase. but its your build. if you want to deal with the headaches of lowering it. giver. what s the point of a lower COG by a few inches if your not wheeling it or racing it?
what kind of truck do you have that'll weight 8 or 9k? my dually on the F450 chassis with the cummins probably won't be over 8500lb.
Old Feb 27, 2010 | 07:48 PM
  #101
okor's Avatar
It's an extended cab duellie with a full width box with stepside boxsides in place of duellie flairs, with the bt6, 5 spd, 205 tcase with full p.t.o. hyd setup to power a under chassis wheelift. Should be pretty stealth, unfortunarly, she'll be pretty heavy as well.
As far as the bracketry problems go, that's one reason I'm putting in the 6" lift. Redesign what I have to and keep the cog low. This is going to be a tow rig. the lower the cog is the more stable it's gonna be. Between the lift and the dropped drivetrain, I should be close to stock while running 36" rubber.
Old Feb 27, 2010 | 08:29 PM
  #102
Do you see what I've been trying to say. the truck is 25' long dual rear wheel. there is nothing more stable than that on the road. even with a 6" lift you won't be losing anything in the stability of the platform. theres a ton of work you could avoid for very very little gain if anything at all with stability.
let me know how it works out for you though.
Old Feb 28, 2010 | 12:36 PM
  #103
okor's Avatar
I do see what your trying to say. Messing with the torsion bar mount won't be a problem due to the lift. Oil pan to diff contact, not a problem either, again, due to the lift. I was originally planning on putting in a body lift to clear the tires, but wouldn't have enough room for the wheellift to function how I wanted it to. The airbag setup was going to cause me some problems, which again were solved with the lift. Putting in the lift will raise the cog. This in itself is not a real problem, but if I can drop the motor when I buld the mounts, why not? I don't shy away from something because it might be a little more difficult. I actually enjoy the build, sometimes more than the result.
Old Feb 28, 2010 | 01:58 PM
  #104
I'm just having a hard time visualizing I guess. thats why I said let me know how it goes.
Old Aug 18, 2010 | 07:32 AM
  #105
BustedWrench's Avatar
Hey Luke, any progress on the "Rhino"? My summer's been stupid busy, waiting for winter to make some further progress on my truck . .. .
Kriesel
Cummins Conversions
Aug 12, 2013 09:06 AM
1st gen Hobie
Oct 7, 2006 10:55 AM
boostjunkie1
Aug 24, 2006 04:56 PM
Joe T
Jul 18, 2006 12:53 AM
doomgaze
Feb 10, 2003 11:44 AM
