Synthetic oil filter
Old Mar 29, 2011 | 11:06 PM
  #91
Lil Dog's Avatar
I am not disputing a dino engine oil usage at all. If you change it like you did, it should last for ever. I was more asking about not trusting the filter for the longer interval is all.
Old May 31, 2011 | 10:06 PM
  #92
Diesel Dave2's Avatar
Pickin on the wrong admin...
Originally Posted by AH64ID
Who is ripping you off? It retails for $24.80 US, which is $24.20 CDN as of this morning!
Found a amsoil dealer in my area...$22.00 including tax....Diesel shops are just ripoffs here (Calgary)...
Old May 31, 2011 | 11:06 PM
  #93
P Kennedy's Avatar
I love these controversial discussions but..... my 2001 which I sold to my brother at 255k on 25k oil changes now has 306k and it still tests lower than most dino oil engines done every 5k? I am confused what should I tell him to do now? I know, drive to 400k the same way like my 91 which was maintained the same way. Why would a high tech nanofiber low micron filter cost the same as a cheap paper filter, no clue but thats what I have used for 800k on 3 trucks. I can't imagine why the last Cat 3406 went 13,000 hours on the same system and lived or the guy I worked for and his 22 trucks and 28 pieces of heavy equipment. Were all wrong! $18,000.00 Cummins B engines are way cheaper than $25.00 filters. Time to go-pot stirred and beds a calling.
Old Jun 2, 2011 | 02:01 PM
  #94
Jim O's Avatar
Originally Posted by Bankdude
I was looking at the amsoil setup but got scared away a bit from location issues and the hose setup. There seems to be a bit of magic relative to what kind of hose connections you use, type of hose and final location. The kit isnt necessarily the end all... I dont remember all the details but in the final analysis it seemed like the risk reward wasn't there. I change way to often (filters at 5k oil at 10k km) running amsoil synthetic and concluded that a broken hose would be far worse than not having extra filtration.
I may have reached the wrong conclusion and would also be happy to hear others experience.
I have the Amsoil bypass and I drilled the valve cover and tapped it to take a 1/8th NPT fitting as I thought the return through the oil filler cap was a bit Mickey Mouse. I also make a point of replacing the hoses ever two years or so.
Jim O
Old Jun 26, 2011 | 10:04 AM
  #95
Did my oil and filter change(15-40)..Unless its all in my head...The amsoil change over sure made the motor way more smoother..Even the slight motor rock I use to get when idling is gone...The truck sure feels alot more looser..
Old Jun 26, 2011 | 11:27 PM
  #96
Dr. Evil's Avatar
I hate the way they sell/market it but its pretty good stuff.
Old Jun 27, 2011 | 09:03 AM
  #97
ccmckee's Avatar
I did the complete switch over on my truck 2 weeks ago to AMSOIL. The tranny seems to slide into gear a little smoother and the motor doesseem to rev a little easier. I'm tracking my mileage to see if there is any difference.I also have a preferred customer number if anyon wants anything FYI.
Old Jun 28, 2011 | 09:38 AM
  #98
Mike Holmen's Avatar
The Guru
Torn apart a few 5.9L and seen a few failures along the way. The thrust bearings on automatic truck seem to take worst damage from the lack of oil/triple disk converters billet flex plates. The common rail guys do more piston damage than the older trucks, not sure how any oil can help there. Most 5.9L even trucks that don't change oil, the bottom end is in mint shape. Only seen one engine so far with whipped mains/rod bearings. The rods needed some TLC to get them true again.
nooska
Nov 12, 2008 02:01 PM
RustyBoltz
May 30, 2008 09:08 PM
bobbywebb
Oct 29, 2006 09:50 PM
rico334
Jan 3, 2005 08:10 AM
snice
14
Apr 29, 2003 08:41 PM
