Stock 5-th gear nut
I think I know what your saying...I locked the first one at 300 FT lbs...Then locked the second one at 300 FT lbs against each other...I'm I missing something??Then 4 spot welds....I don't think the spot welds will do much....Because I hardly got the metal hot for a really deep penatration..
I was going to go with the next size bigger...But when I looked at it,the tapp would of taken a big portion on the nut metal and tread away away..
Looks good! I think that should deffinetly fix the problem. The aftermarket one I used had set screws about the same size as the ones you used. 25,000 kms and counting (fingers crossed)
Should be ok for my truck being that I don't race it or drive it hard.I couldn't see myself spending over $1,000 for a output shaft unless I really had to..If it works for many miles,great...If it does fall off...Oh well, I tryed something different..A modded double nut ..
A little dusty...Rob was polishing his teeth with the orbital sander..
Pretty.......shift cover,side plates and tailshaft glass beaded,painted with whatever base paint I could find then cleared coated...Main case,1986 GMC red acrylic enamel...I will look dam good if I land up, upside down in a ditch..
Clane
Jun 2, 2012 03:31 PM
LemonDodge
Sep 16, 2010 07:33 AM
wadecool
Nov 13, 2006 12:37 AM
