another guage problem for you guys
Old Jan 30, 2009 | 05:15 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
I've got everything hooked up except my boost line. I have autometer phantom guages so there's wires everywhere. My problem is; when I turn on ignition, tranny temp guage immediately goes right up to over 250* without even starting the engine. Do I have the positive and negative reversed or what? After starting engine, no reading on pyro; doesn't even budge. Shouldn't it move a little when engine is idling? I'm baffled!
Andy
Old Jan 30, 2009 | 11:08 PM
DODGER BOMBER's Avatar
well the tranny sounds like its backwards and the pyro sounds like its not getting power. were did you get your keyed power from??? Also does the pyro move when ur driving???
Old Jan 30, 2009 | 11:50 PM
Eat Beef's Avatar
Got my keyed power from the #28 fuse under the hood. Pyro doesn't move while driving.
Old Jan 31, 2009 | 12:16 AM
Dr. Evil's Avatar
Make sure you are grounded to bare metal and separate the grounds if you have more than one tied together
Old Jan 31, 2009 | 09:44 AM
Well the best power for gauges i found is lighter plug. On the 3rd gen anyway. ya just go over your grounds and make sure its bare metal.
Old Jan 31, 2009 | 12:57 PM
Eat Beef's Avatar
Okay, thanks to all. Got the tranny guage working. It was a bad connection at the sender. I'm using the same ground location for all. Tranny works, lights for guages work so I assume the pyro should work. Might have to separate that one eh?
Old Jan 31, 2009 | 04:57 PM
Tate's Avatar
Check the connections at the back of the gauges. When I first put gauges in the dually, my pyro would read 1000F at idle, and peg out just idling down the road. One of the wires in the connector had pulled back a bit, causing a poor connection and wacky readings.
jcmoyer2004
Oct 29, 2009 03:54 PM
MikeThomas
Mar 30, 2007 08:17 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
bigragu
Jan 24, 2006 11:16 AM
