Programmer without deletes
Old Jul 16, 2013 | 09:29 PM
Duckincrazy92's Avatar
Is anybody running one? If so what kinda mileage are you getting and what brand?
Old Jul 19, 2013 | 12:43 PM
Beast2B's Avatar
I've run my Smarty with all emissions equipment intact and plugged in. I gained ~1mpg average in varied driving. The throttle response is much improved especially in the low rpm range
Old Jul 19, 2013 | 12:47 PM
Do you plan on deletes?
Old Jul 19, 2013 | 12:54 PM
Beast2B's Avatar
I've gathered a pile of parts to try and see what combo works for me. I'm in Cali so I have emissions testing every other year, so I take that into consideration. I have a Smarty S67 and an H&S XRT Pro with Norcaler's software for programmers. I have a delete pipe from turbo to muffler as well as a stock DPF/NOX section hollowed out as well. I haven't started playing yet, but I like the stealth of the stock canisters as opposed to the delete pipe. That's where I'll start and try it with the Smarty to get some baseline numbers. Norcaler is close to me, so I will also work with Aaron to optimize the H&S for my truck.
Old Jul 19, 2013 | 04:32 PM
We don't have emissions on diesels here. I just worry about my warranty.
Old Jul 19, 2013 | 04:52 PM
Beast2B's Avatar
either way the warranty should be considered iffy! Deleted or not, adding a programmer can be detected by the dealer techs if they look hard enough.
Old Jul 19, 2013 | 08:53 PM
I understand that. I'm not gonna do a programmer unless I do deletes. Especially if I would only get 1 mpg better.
Old Jul 19, 2013 | 09:06 PM
Beast2B's Avatar
Look up sims here or at cumminsforum. Some guys have deleted with no programmer at all just removing the DPF/NOX and installing sims.
Old Jul 19, 2013 | 09:16 PM
I'll look it up. I been looking around and think if I delete I want to get a mini maxx and 5 inch flo pro turbo back
Old Jul 19, 2013 | 09:59 PM
67guzzler's Avatar
Lots of us have run SIMS for extended periods of time. Having SIMS as an option even if you go the tuner route is useful if you need to flash back to stock for some reason but don't want to have to put all your hardware back to stock. If anyone wants more information, PM me. I wrote up a "HOW-TO' on the other forum but I don't want to crosslink.
-Guzzler
Doj Dewd
Dec 14, 2013 07:38 PM
krusty 2
May 23, 2012 05:10 PM
chrigu
Aug 11, 2009 07:55 PM
JaimeG
Mar 26, 2009 06:58 AM
Speed Shift
34
Jul 10, 2007 10:40 AM
