2011 DPF Deletes and Programmers
Carefull on how much you turn up the power on a stock RFE68 transmission, they can take some abuse, but not tons of abuse.
The G56 clutch will slip on kill mode.
I drive my truck on stock power level, 99.9% of the time. Just by dropping off the cat/dpf, you probably pick-up 20rwhp. The turbo will spool better and the egt's will be lower.
I am running my xrt on the wild setting which would be the middle one. It is running soo well. I have the G56 and i am not sure but i have a feeling that if i put the hot program on and got on it it would probably slip the transmission. Anyone try it yet??? i really dont want to be putting a south bend in just yet. Anyone know if you can slip it on the wild setting??
The xrt pro is awesome!!!
Which verison you guys running? Any body done the fuel rail pressure shim? Helps keep fuel in the rail. Running a fass or air dog?
I run mine on stock mode 99% of the time, the truck works good enough for what I'm doing. I have other trucks to do some playing with. I have to have one truck that not to modified.
I have a fuel rail plug and like i said i am running the wild setting and i just take it easy but i have not yet slipped it>> just wanted to know if you really get on it can you slip it on the wild setting?? how about the mild setting??
"Hello,
the new software for Smarty JR67 and Smarty JR67ME, compatible to 2010 trucks, is currently under beta-test.
It will be available soon.
Stefano Negrini - MADS"
I would assume they will work for 2011 as well?
Phrederic
Oct 16, 2014 09:29 PM
GavinS
Introductions / New People
Aug 31, 2014 07:04 AM
cfdlighthouse
17
Jun 11, 2012 09:20 AM
jcmoyer2004
Mar 12, 2010 07:38 PM
