4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Service Air Filter Message
Old Aug 13, 2011 | 03:26 PM
stidwell's Avatar
I thought I would revive an old post to see if others have had the problem.
I can make the "Service Air Filter" come on if i squeeze the skinny pedal too hard at one time.
Does anyone else have this issue?
Its a little irritating, but i live with it.
It makes me wonder if the filter is allowing enough air through.
What are you doing to correct the issue? K & N drop in? other high flow filter?
Old Aug 13, 2011 | 04:16 PM
burlhall's Avatar
My truck does the same thing as you described. However, the message goes away the next time I start the engine. I have only had it to happen twice and both times I was accelerating to merge into heavy traffic. The first time it happened I pulled the filter and it did look a little dirty so I installed a new one. The second time it happened was shortly after I installed the new filter so I assumed the filter was still ok. I think the problem is being caused by a program glitch.
Old Aug 13, 2011 | 04:28 PM
stidwell's Avatar
Mine goes away the next key turn also....
Old Aug 13, 2011 | 04:36 PM
6 Shaker's Avatar
stidwell,
When was the last time you had your truck re-flashed? I too was having that problem last summer but I took my truck into the dealer and they re-flashed and I haven't seen the message since. Every hill with the trailer on last summer the message would come up and I have not seen it at all this camping season.
Old Aug 13, 2011 | 08:31 PM
Dodgefirst's Avatar
I have had this happen several times. Had the dealer check things out. No problem ever found. Last time this message appeared, was camping with friends. My friend and I decided to pull out the air filter. Bottom of filter had about 3 inches thick of mouse nesting material ! No more problems sine then . Oh BTW, the air intake hole on the inner front fender is big with nothing covering it to prevent vermin!
Old Aug 15, 2011 | 12:47 PM
stidwell's Avatar
The truck was flashed about a month ago.
Old Aug 15, 2011 | 05:38 PM
cbrahs's Avatar
S&B has reset their release date for their filters just because of this issue. not going to release until they have no issues.
Old Aug 15, 2011 | 08:46 PM
burlhall's Avatar
Who is S&B. I use Fleetguard filters.
Old Aug 16, 2011 | 07:52 AM
cbrahs's Avatar
http://www.sbfilters.com/Intake-Dies...s-6-7L-75-5057
Old Aug 16, 2011 | 08:26 PM
Busboy's Avatar
I notice Amsoil doesn't have an EA filter yet but they do have a wix, perhaps this is the reason?
stidwell
Mar 25, 2014 03:58 PM
Pavedragon
Jul 8, 2010 05:16 PM
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
nfsommer
Apr 16, 2007 09:21 PM
