Upgraded steering
Old Nov 22, 2008 | 09:20 PM
  #61
BroncoHound's Avatar
FYI to anyone interested, dodgeparts.com has 52122362AB for $138 in their OEM catalog. They don't have a listing for 52122362AE.
Old Nov 22, 2008 | 10:16 PM
  #62
Danderson's Avatar
I keep punching in that part# in the oem catalog and it keeps coming up "No parts in this catagory"?
Old Nov 22, 2008 | 10:22 PM
  #63
Danderson's Avatar
I got it! need to enter "2008" in the model year. Thanks. $138+ $13.80 shipping. Good deal
Old Nov 24, 2008 | 09:18 AM
  #64
ohyeahfriday's Avatar
And that is for the steering setup pictured previously by mitternocht on the last page? The page doesn't give any description, so I just want to make sure.
Thanks a bunch for the info!
Old Nov 24, 2008 | 12:27 PM
  #65
That is the part number my dealership gave me for the upgraded steering unit so, as far as i know, it is correct. I haven't ordered them (still thinking about trying to get it warranteed as i am right at about 35000 miles on my '08) so I can't say with absolute certainty, however.
Old Nov 27, 2008 | 09:55 AM
  #66
Treangen's Avatar
Has anyone found a bilstein 7100 or maybe the fox that Thuren uses to put on as a stabilizer? It seems the new steering setup has all the mounts for the stabilizer but you just need the shock. Part numbers anyone?
Old Nov 27, 2008 | 02:01 PM
  #67
Torque master's Avatar
Turning Radius on an 05-2500-- Trying to figure why my turning is so poor on my 05 Truck-- I am Running a 4.5 Inch Fabtech Lift with Only 17-Inch By 8-Wide Pro-comp Wheels With 305" Tires.
basically just a little smaller than 33- 12:50's Anyhow I have the Kit that Has the Upper Hoop That Two Res- Shocks Mount too. Anyhow I try to look and see where the Contact point is with my Wheels fulling Turned and Why I am no getting the Turning I had in Past with the likes of my Thuren Fabrication Lift where like on most of the lifts for these 2500 Cummings the Shock Goes Through the COil Spring, Well on mine it Mounts to the Upper Hoop Mount and Only a securing Strap Runs Down through the Coil Spring on mine.
I know it must have to DO with this Lift just trying to understand or locate contact point.
I Want my Turning Ability back, I do not like to have to do those 3- point back -up's to make a Turn if you know What I mean, like I always Dealt with on GMC / Ford Trucks 3/4 Ton / 2500's
Any feeback on to what maybe causing this will be greatly appreciated.
Old Nov 28, 2008 | 07:48 PM
  #68
ImpulseHydro's Avatar
Does anyone know if the pitman arm from an 05 is the same as an 08?. My parts guy has checked and cant find the part number for and 08..
Doug.
Old Nov 28, 2008 | 09:47 PM
  #69
Pull Ya's Avatar
Try 68039930AA-pitman arm.
Jay
Old Nov 28, 2008 | 09:54 PM
  #70
The rest of the steering setup is the same so i assume the pitman arm is as well.
Old Nov 29, 2008 | 05:34 PM
  #71
Thanks for the info, But I have one question,
Is the 05 pitman arm the same as the 08? Or do the 08's have a different angle to them?
Doug.
Old Nov 29, 2008 | 05:38 PM
  #72
Matt400's Avatar
They are different. I have one coming the first of the week and will get a pic of the two side by side.
Old Nov 29, 2008 | 05:43 PM
  #73
PitMan Arm-05
I Do not know about that, I am tryin to resolve if an up-graded Pitman Arm Will Provide me better Turning Radious then I am getting Currently Running this Fabtech 4.5 Inch Kit, that has the Dual Upper Shock Hoop Mount.
This system Does not Run the Shock Through The Coil Spring like most lifts for the Ram-2500 seem to.
Anyhow I have Really Bad Turning Ability and trying to figure it out, Only Running 17-inch by 8-Wide Wheels with 305 Tires just a little smaller then 33----12:50 Tires.
The only Thing I can Figure is If I had a modified / Upgraded Pitman Arm to help provide Turning Ability.
Old Nov 29, 2008 | 05:53 PM
  #74
Matt400's Avatar
You should be able to see where the trouble is by supporting the front axle with jack stands and turning the wheel. You could even have trouble internally with the steering gear. Pop the linkage apart from the pitman arm to see if you get any more turn.
Old Nov 29, 2008 | 07:02 PM
  #75
bob4x4's Avatar
Carli has a unit that bolts on
