Two Piece Fuel Filter?
Old Nov 22, 2006 | 07:19 AM
Slo'n Down's Avatar
Changed my filter (1st. time-10k) and when I turned the lid off of the canister the filter stayed put. The plastic filter top was attached to the lid but I had to pull the filter out. Is this normal? Small amount (1/2 spoon full) of stringy sludge in the bottom of canister that I assume is normal?
The local Cummins dealer has only 10 micron filters. Parts guy says thats all that is available. I guess I'll order on-line next time to get the 7.
Old Nov 22, 2006 | 07:41 AM
bluebull's Avatar
The plastic top of the filter should have stayed on the paper part. Sounds like that filter could have contaminated your fuel system by inproper filtration. The good part is if your truck is running fine there should be nothing to worry about. The stringy stuff at the bottom could be water with bacteria in it. Drain your fuel filter more often to remove this stuff. Try to find which fuel station gave you the contaminated fuel and buy some where else from now on.
Old Nov 22, 2006 | 07:43 AM
Turbobob's Avatar
The filter is a 1 piece unit, the end cap should not have departed the filter! Document what happened to the filter, keep it in a bag if you still have it. Sounds like the filter failed and you may have pump & injector problems in your future!
Old Nov 22, 2006 | 08:02 AM
Hercules130's Avatar
I just changed my filter and there is sand at the bottom of the canister! I drained it but the sand stayed put. how do i get the sand out?
Old Nov 22, 2006 | 08:45 AM
Slo'n Down's Avatar
Thanks for the response. I assumed the filter was a problem but wanted to make sure. To late to save the old one, should I contact the dealer to have this info. on file or is that spitt'n in the wind?
Truck seems to run same as always-awesome!!
Old Nov 22, 2006 | 09:20 AM
bluebull's Avatar
If the filter was the original one I would contact them about it and make sure it's documented as in have paper in your hand.
If the filter is one that you changed earlier, contacting the dealer could be setting yourself up for warranty denial later because the failed filter is the filter manufacturers responsability from that point on and not having the filter to prove it failed leaves you in a shaddy area.
Old Nov 22, 2006 | 09:23 AM
bluebull's Avatar
The best way is with a wet/dry vacum. If the hose is too big shove a smaller pipe into it and duct tape it.
Old Nov 26, 2006 | 08:48 AM
Gemstone's Avatar
The best way to deal with the engine compartment fuel filter is to eliminate it.
Poor engineering by Mopar...messy and that o-ring is easy to pinch.
I had the fuel line cut under the frame, below the drivers seat, installed two petcocks, a spin on filter housing, and a Fleetguard FF105 filter. I can have it changed in less than a minute, no muss, no fuss. Now if only Dodge would make the oil filter easier to reach....
Regards
Gemstone
samiam4
Sep 26, 2010 06:04 PM
Death Dealer
Feb 22, 2008 03:58 PM
monnshyne
Dec 4, 2006 11:54 PM
rjm022
Feb 4, 2006 08:02 PM
SLEDHEAD
Oct 11, 2004 03:10 PM
