2- piece vs 1 piece driveshafts
Old Sep 26, 2010 | 11:22 AM
samiam4's Avatar
Guys,
My D250 has a 1 piece drives shaft. On my GMC, the way I got rid of highway boom(loud) was to go to a 2-piece shaft.
I have a long wheel base-non extended cab SLT(?) D250. Can I find a 2 piece shaft to replace the 1 piece????
M
Old Sep 26, 2010 | 01:46 PM
Trebor's Avatar
I had a '90 Dodge Cummins automatic 2WD 2 piece drive shaft that I had the front shortened and the rear section lengthened for the crew cab. That should indicate that they are out there. You will also need the crossmember, the flanged mount center support bearing, and the bearing mounting extension bracket if it came with one. Mine came with the heavy wall 4" tubing.
Old Sep 26, 2010 | 06:04 PM
deanhinsley1963's Avatar
I always liked a one piece drive shaft when possible. my reg. cab.dually has a 1pc. less to go wrong/carrier brg.,another u joint,jack shft splines to wear out. just my 2cs.
Russell
Sep 9, 2009 06:41 PM
05doolie
Jun 7, 2009 08:05 PM
trik396
Apr 11, 2005 04:47 PM
gatf4
Mar 9, 2005 11:52 PM
RATTLINRAM
13
Jul 19, 2004 06:39 PM
