Driveshafts
Old Feb 2, 2004 | 10:16 AM
Russell's Avatar
Question Driveshafts
Does anyone know why on the earlier 12v 4x4 5spd's there is what looks to be some kind of balancer near the t-case and on late (98 12v) there isn't one?
Old Feb 2, 2004 | 08:10 PM
Smokee's Avatar
I don't know about the 4X4, but on the '94 there was a TSB that installed a large balancer to eliminate a vibration/drone under acceleration at higher speeds.
george
Old Feb 3, 2004 | 08:43 AM
Russell's Avatar
I dropped my driveshaft (the yoke with the balancer) when I had it apart for u-joints and the when I put it back together I had an awful vibration @ 110kph 60mph. It was so bad that I thought the outputshaft bearing had packed it in. I went to the wrecking yard and got a driveshaft out of a '98 and it was missing to balancer. So far the only difference I have noticed is when I lug the motor to 1000rpm then accelerate there is a drone. I can live with the drone but couldn't live with the vibration.
Old Feb 3, 2004 | 10:57 AM
radixr's Avatar
Russell,
All you need to do with your original driveshaft is get it balanced. Replacing your u-joints is enough to put it out of balance (unless it got bent when it was dropped).
Old Feb 4, 2004 | 10:58 AM
Russell's Avatar
The balancer fell off of my workbench and landed on the concrete floor which resulted in a 2" flat spot on one side.
Old Sep 9, 2009 | 06:41 PM
Cam73's Avatar
Any updates on this? Every local shop tells me it is there for a reason and needs to stay/be replaced if falling off or damaged. The one in my truck is suspect and I don't see why a good balance job would not do the trick..
kas83
Sep 18, 2007 09:06 PM
XLR8R
Jan 19, 2007 05:28 PM
trik396
Apr 11, 2005 04:47 PM
gatf4
Mar 9, 2005 11:52 PM
RATTLINRAM
13
Jul 19, 2004 06:39 PM
