Moving A/C controls
Old Jun 1, 2005 | 05:47 PM
Prodart440's Avatar
Moving A/C controls
I have seen on this site that someone moved the A/C controls down, in order to put guages where the controls were. Any idea who makes the kit and what is involoved???
Thanks Aaron
Old Jun 1, 2005 | 06:41 PM
The Domie's Avatar
Look at the thread titled- moving the 4h/4l switch
Old Jun 2, 2005 | 04:39 AM
TexasCTD's Avatar
MEDICSHAWN did that to his truck. I don't know if there was a kit involved or not.
https://www.dieseltruckresource.com/...cat/500/page/1
Old Jun 2, 2005 | 06:57 AM
MedicShawn's Avatar
No kit just a file a Dremel and some epoxie. see t6his writeup I did.
https://www.dieseltruckresource.com/...;threadid=54029
Old Jun 2, 2005 | 10:09 AM
LinearX's Avatar
Link doesn't work.
Old Jun 2, 2005 | 10:29 AM
MedicShawn's Avatar
I'm not sure what's up with the link here's the write up.
Electronic transfer case heated seats relocation for cubby hole gauges
I wanted to mount 3 gauges in my 3rd gen but didn't want to loose my grab handle. I didn't like the dash mount or steering pod option either. So I decided on the Autometer 3 gauge cubby hole mount. The only problem there is I have a Laramie so I have the electronic transfer case switch and the heated seat switches.
So I decided to relocate the electronic transfer case controller and the switches for the heated seats. I decided if I was going to move things around anyway I would move the HVAC controls down and mount the gauges in the middle below the radio.
The first order of business was enlarging the lower opening to fit the HVAC controls. The HVAC controls are slightly larger than the cubby hole opening on the bottom. I had to enlarge the opening by 1/8-1/16 mostly on the bottom.
Next I installed the gauges into the Autometer gauge pod. I have Dipricol gauges so I had to work on the braces that hold the gauge pod to the center console of the truck. Autometer gauges mount on top and bottom and the Dipricol gauges mount on the sides. So I used some L shaped corner braces I bought at the hardware store and cut/bent/drilled them to fit. This part was pretty time consuming because the tolerances are close since the gauge pod was designed to fit the smaller lower hole.
I next embarked upon cutting the dash to fit the Electronic transfer case and seat controls. I cut the Laramie panel where the drivers heated seat switch had been. I then cut the dash where the cigarette lighter had been and epoxied the electronic transfer case in place. To get this to fit I had to also cut out a portion of the dash for clearance behind the control.
I then cut out for the heated seat controls to the left and right of the newly relocated HVAC controls. I expoxied them in place also.
I didn’t have to cut or splice any wires but the electronic transfer case was pretty snug. Make sure you mark the proper wires for the heated seats as well as the switches because the switches are designed to go with the corresponding wires.
Pics are in my gallery
Old Jun 2, 2005 | 11:37 AM
Prodart440's Avatar
Thank you very much. I will be doing this as soon as my pod gets here.
Aaron
Old Jun 5, 2005 | 11:28 AM
Deke's Avatar
That is a SWEET custom install Shawn. Thanks for all the detailed info.
ATVConnection
Oct 28, 2004 07:20 PM
Eric Bertram
Feb 17, 2004 08:45 AM
chrismez
Jan 7, 2004 01:59 PM
RamThatStroker
Dec 28, 2002 06:44 PM
patriot pearl blue
Dec 28, 2002 12:44 PM
