"Lamp out" light on?
Old Feb 13, 2009 | 09:08 PM
shaft's Avatar
The 'lamp out' light is illuminated in my dash but i don't see any headlight, fog light, tail light or any other light that is burnt out. Is there something wrong electrically with the truck? Anybody experienced this before? What else should I check for other than burnt out bulbs since i did not see any?
Old Feb 13, 2009 | 09:52 PM
Stovetop535's Avatar
I posted awhile back about this same problem. Check your brights. That bulb was out on mine for awhile and I missed it. Otherwise my light likes to come on...and I cannot figure out what bulb is out.
Good Luck!
Old Feb 13, 2009 | 09:54 PM
FMB's Avatar
FMB
You might actually be the very last of the '03 owners to not experience this yet.
Check the light over the rear window. If that is good and your license plate lights are good, buy a set of tail lights and replace them all. It isn't worth the bother otherwise. Use dielectric grease on the bases too.
Old Feb 13, 2009 | 10:01 PM
drewkeen's Avatar
Would reverse lights being out trigger it?
Old Feb 13, 2009 | 10:40 PM
SuperGewl's Avatar
DUH You betcha
Old Feb 15, 2009 | 03:01 AM
MFEUSAF's Avatar
this is probably the most annoying indication ever.... i had a bulb "going out" and the little chime and lamp out indication freaked out for about 50 miles... i wanted to just shoot it!
Old Feb 15, 2009 | 04:45 AM
jpfishmaster's Avatar
That thing nailed me a couple of years ago; license plate marker light
Old Mar 15, 2009 | 03:49 PM
Highway 4x4's Avatar
Is there a way to disable that warning ??????????Kill it???
Old Mar 15, 2009 | 04:19 PM
huck25's Avatar
I have aftermarket hid lights and ever since i put them in i've had that code show
Old Mar 15, 2009 | 07:42 PM
nsxt's Avatar
This was pretty annoying up until the time a taillight actually failed.
Up until 04.5 or so, the taillight PCB has weak springs holding the bulbs in. Upgraded PCBs are available but I just cleaned and bent my springs a little closer together.
Somewhere here there is a thread on this subject with photos showing heat damaged contacts due to the weakness.
Old Mar 15, 2009 | 07:55 PM
justin mcfall's Avatar
check your turn signals..
Old Mar 15, 2009 | 07:57 PM
briannutter0304's Avatar
my 03 did it for about 1 year would ding for a week then go away for about 1-2 months then it would come back. I didnt have any lights out or anything, so i went it and found a ground wire in the light wire harness and spliced a piece of wire into it and screwed it right to the frame. seemed to do the trick. Make sure it is a ground wire tho.
Old Oct 19, 2011 | 09:23 AM
sawboywv1's Avatar
Wire
Where did you tap into?
Hoss
21
Dec 3, 2016 02:49 PM
Dieseldude4x4
Jun 22, 2007 08:25 AM
ajpulley
19
Jul 11, 2006 03:18 PM
Buffalo
Mar 15, 2006 05:26 PM
Pickle
Mar 26, 2005 11:57 PM
