fuel filter leaking again!
MY fuel filter appears to be leaking from the top area somewhere. I think the O-ring is not seating properly or maybe I'm not tightening it down enough or too much? What is the exact torque specs for the fuel filter? Can I buy only an o-ring somewhere?
I just use a cresent wrench, dont know the torc number, did you use a little diesel or grease on the o-ring when you changed it and filter. I have never seen the o-rings sold seperate.
You may have pinched and torn the o-ring in the process of installing it, which will not create a good seal no matter what you do. The o-rings are not available separately. I recommend you use a 11/8" six point socket to remove and replace the filter cover in order to keep the cover edges from damage. The torque spec is 24 ft.lbs.
always put some vaseline (or similar) lube on any o-ring when installing. keeps it from pinching. the plastic cap is known for leaking anyways. look for a billet cap.
Where can I get a billet cap? Also, what local parts store sell the fuel filter and o-ring? I have only got mine at Genos.
I bought a new plastic cap at Napa for $15 with O-ring also. It came with a piece of paper that says:
"Permatex high temp. thread sealant or equivalent must be applied to the threads before installing this part"
That doesn't seem right? It doesn't get that hot in the fuel filter does it? I thought I could just put a little vaseline and be dome with it?
Not long ago I had mine leak. I thought that the increased pressure from the FASS, 16 psi, was causing the leak. I ordered a billit cap from Geno's to replace the plastic one. While it was on the way I replaced the filter and O-ring and it stopped the leak. I will put on the new cap the next time I change the filter. I use diesel fuel to lub the O-ring and a 1 1/8 socket on the cap.
