Infinity Sound System ???
Old Mar 8, 2007 | 11:01 PM
bucknasty's Avatar
It may be the head unit....I just installed the 6 disc and tried out the rear speakers only. They sound about half as loud/clear as they did with the single disc stock unit.
Old Mar 9, 2007 | 06:37 AM
jaybone's Avatar
My 03 has similar problem with the infinity, but it is the front speakers that sound awful, and the back sounds great., I tried the pin switch, new speakers, and still no joy. also have no radio lights when key is in acc position.
Old Mar 9, 2007 | 06:39 AM
jaybone's Avatar
does anyone know if there should be 2 plugs on back of the stereo? I can only find one and assume the amp plug is missing(if that is the top plug)
Old Mar 9, 2007 | 07:27 AM
Buckshotmckee's Avatar
***Update***
Here is the latest on my Infinity problem. They (dealer) installed a new amp, there was problem with the connector when the new amp was plugged in, blew 2 front speakers. Connector fixed, new amp in, new speakers will be in today for the front doors. Aside from the blown front speakers, this looks promising. I'm getting more punch/sound out of the rear speakers now. I still don't think those little 5 1/4 speakers are adequate. Does anyone know if 6 1/2 will fit without cutting the doors, or other suggestions????
Old Mar 9, 2007 | 09:03 AM
ecarl357's Avatar
6 1/2" will fit in the rear doors......or at least they do in an 06 Mega cab. You can look at the crutchfield site, that may offer some more info.
Old Mar 9, 2007 | 09:46 AM
simadownow6988's Avatar
yeah, changing around the speaker wires is a no no .
That will put your system out of phase.
Old Mar 15, 2007 | 08:20 AM
schv's Avatar
I'm having an issue with upgrading the speakers on my REC Infinity equipped 07. I installed new Infinity 6x9's in the front doors (aftermarket Infinity Kappas), only to discover that the highs are filtered out of the door speakers, probably by the "amp" under the dash. Does the aforementioned bypass cable from Crutchfield correct this? Does the REC have its own built in amp that can drive speakers well enough? Also, would the dash speakers still be functional? (if not no biggie)
I'm replacing front and rear door speakers, and the rear speakers get full bandwidth but the front door speakers are apparently supposed to just be woofers, as evidenced by their construction. I almost regret getting the factory 7 speaker setup, but it was included in the "H" Laramie package.
Old Mar 15, 2007 | 08:45 AM
What size did you go with in the rear doors???
Old Mar 15, 2007 | 09:13 AM
schv's Avatar
I bought Infinity 6.5" "Reference" 2 way coax speakers for the rear doors. They are a thin profile for clearance and need a couple of holes drilled for install. I haven't put them in yet though.
Old Mar 15, 2007 | 09:39 AM
Cool Thanks! Do you know if your going to have to cut/open the holes up in the rear doors for them to fit???
Old Mar 15, 2007 | 09:47 AM
ecarl357's Avatar
You don't have to do any cutting. The holes in the doors are made for a 6 1/2" speaker. The factory uses an adapter plate to fit the smaller 5 1/4" speakers. I replaced the entire radio system in my truck, and all I did was simply remove the rear speakers / adapters and use metal screws to mount the new 6 1/2" to the rear door.
Old Mar 15, 2007 | 09:59 AM
Thanks!
Captain
26
Apr 23, 2010 06:01 AM
JPR Ram
May 25, 2007 11:37 PM
RamRodder
Sep 2, 2006 12:41 PM
Rammer64
Jan 9, 2006 09:44 PM
signature600
Sep 16, 2004 02:35 PM
