How to remove headliner?
Old Dec 4, 2008 | 05:17 PM
MOAGGIE's Avatar
Anybody got instructions on how to remove the headliner on an 2005 Quad without messing it up? Got a new set of cab lights and need to install them. thanks for any help.
Old Dec 4, 2008 | 05:29 PM
RamWheelsBy4's Avatar
I will post the removal instructions from the DR Service Manual when I get home tonight.
Old Dec 4, 2008 | 05:46 PM
MOAGGIE's Avatar
thanks that would be great. I am pretty good mechanically just a little leary of trying to do something like this. Tried to work on my dads old impala one time.....lets just say it wasn't a pretty deal. thanks again for the info.
Old Dec 4, 2008 | 05:47 PM
pvdh286's Avatar
headliner
I just did my 95 club, I had to remove seat to get it out, I used 2 sided tape to put it back up so it stays put, remove everything you can that is in the way, do not bend it, it will take 2 people to putit back up, have fun. pete
Old Dec 5, 2008 | 12:20 AM
Sorry, I was late getting home tonight. See if this helps. Let me know if you need any of the referenced removal instructions.
Old Dec 5, 2008 | 04:51 AM
sabersix's Avatar
I did the cab lights on my MC. Only needed to drop the headliner down so it rested on the tops of the headrests. I didn't have to completely remove it. The biggest PITA was the rear entertainment system, so if you don't have that then it should be pretty easy.
Two notes:
The plastic trim for the A-pillar "scratched" the inside of my windshield when I pulled them out. Not really scratches but marks on the glass that I can't get out. Not real obvious, but visible if you look.
The plastic anchor nuts for the cab lights tend to spin if the hole is even just a little bit too big. You may have to use a part of pliers on the underside of the roof to hold the anchor while tightening the screws. Be sure to get them tight so the light will not leak.
Old Dec 5, 2008 | 08:17 AM
MOAGGIE's Avatar
would it hurt any thing by putting some sealer around the holes to make sure it doesn't leak?
Old Dec 5, 2008 | 09:17 AM
rockcrawler304's Avatar
I am not too sure how the light mount because I have never done it but I would say to put the sealer on the outside under the light if possible to avoid leaks. I say this because when you drill a hole there will be exposed metal (the inside of the hole) and the water could sit there if the sealant was on the inside. Hope this makes sense. I can picture it but kind of hard to explain
Old Dec 5, 2008 | 09:36 AM
Rtikul8's Avatar
I left the headliner in as well, just got a small box and cut it down to about 4 inches thick. Then put the box under the hole I was going to drill, it holds the headliner down for you and catches the shavings from the drill bit at the same time.
RoadDiesel
Aug 7, 2012 06:06 PM
Dodgezilla
Jul 17, 2004 05:24 AM
quantrill88
Mar 23, 2004 06:08 AM
cumminsdriver635
Jan 31, 2004 07:06 PM
Rattlerattle
Aug 22, 2003 09:49 PM
