Roof headliner
Old Aug 21, 2003 | 02:29 PM
Rattlerattle's Avatar
Roof headliner
So the headliner cloth material is starting to unstick from the cab of the truck. What kind of adheasve is best to put it back with?
Are they glued from the factory?
Thanks in advance.
Old Aug 21, 2003 | 03:58 PM
James Lucas's Avatar
Re:Roof headliner
Rattle,
The cloth is coming off the foam backing... Any glue you use will saturate the cloth and show. When you buy new headliner material it will come with foam backing on it and that is what you glue to the hardboard.
To redo your headliner just remove your hardboard and take all the cloth and foam off...Carefully
Spray Contact Cement such as 3m on both the hard board and the foam backing of the material and let it dry for a few minutes.
You are now ready to apply the new material to the hardboard. Lay it out over the harboard barely attaching all four corners.
With your clean hands start in the middle and press and smooth the material onto the harboard working your way out to the sides.
After all material is smoothed out use a razor blade and trim the cloth to fit and cut out all the holes.
Re-install in your truck.....
James
Old Aug 21, 2003 | 06:28 PM
Wilson's Avatar
Re:Roof headliner
I wonder if it would be beneficial to put some dynamat or something comparable up there to deaden some sound before you lay the material?
Old Aug 22, 2003 | 07:24 PM
Re:Roof headliner
So sounds like I have to replace the material and backing.
Thanks for the info.
RR
Old Aug 22, 2003 | 09:49 PM
Re:Roof headliner
Ya Rattle thats the BAD news... The good news is it is real easy and the material is really cheap! Should cost you less, MUCH less, than 15.00 per yard and you won't need very much at all.
We used to install them for people for 60.00 10 years ago and made money. Back then the material cost us 6.95 per yard.
Thats how quick and easy it is....
Material is sold by linear yard (3') at roll width so 1 yard is 3'x width of roll. Not 3'x3'
Good luck.....
James
Roperteacher
Nov 16, 2007 10:13 AM
ARAcummins
Sep 6, 2004 11:54 PM
dodgediesel4x4
Apr 19, 2004 01:23 AM
quantrill88
Mar 23, 2004 06:08 AM
cumminsdriver635
Jan 31, 2004 07:06 PM
