2 lube points
Old Jul 13, 2007 | 11:45 PM
  #31
Danavilla's Avatar
Nate-03 D's sig indicates he has an '03. I don't think they put the fitting on the cardan joint until '06. I may be wrong. You should have a decal in front of your radiator if your truck has the fitting. It also should be shown as part of your service schedule.
Dan
Old Jul 14, 2007 | 08:10 PM
  #32
Bark's Avatar
Gawd..Thats probably why I couldnt find it on my 03 or in my owners manuel. Anybody else know what year they started putting them in?
Old Jul 14, 2007 | 08:17 PM
  #33
wreedCTD's Avatar
Can someone post a pic of what the lube joint looks like up close?
Old Jul 14, 2007 | 10:39 PM
  #34
Danavilla's Avatar
https://www.dieseltruckresource.com/d...d.php?t=127834
Also, do a search. There have been quite a few posted.
Dan
Old Jul 14, 2007 | 10:53 PM
  #35
Danavilla's Avatar
Here's another
https://www.dieseltruckresource.com/...elds&name=donu t&name=donut
Dan
Old Jul 15, 2007 | 11:46 PM
  #36
drdigger11's Avatar
There isn't one on the 03's, just two grease nipples, one on each side of the cardan. Serviced mine the other day and checked for the 10th time to make sure. It isn't there on ours. It makes you think listening to everyone else talk about it though.
Old Jul 16, 2007 | 12:37 AM
  #37
Bark's Avatar
LoL drdigger11. Thanks for the info. Guess I will just go back to looking for my water pump weep hole.
Old Jul 16, 2007 | 03:11 AM
  #38
Deesil's Avatar
Muted User
I believe they started putting the female zerk in the Cardan joint in '05, I know my '04 doesn't have one, I just pulled out my driveshaft and replaced the front joints with serviceable one's. I also replaced the ball joint in the Cardan as well.
I would probably start greasing your 4 ball joints as well when it hits 40-50k on the clock. There is no zerk on them, you have to get a needle attachment for your grease gun and puncture the rubber boot and fill it full of grease. The ball joints on these trucks take a beating and it would be a real good idea to keep them greased to prevent early failure.
Old Jul 16, 2007 | 11:08 AM
  #39
Nate-03 D's Avatar
Dan
Yea I realy don't think that I have the needle grease zerts, I looked again and no luck. I know im near sighted but im not that blind, they are not there.
And I have no decal stating that I need to lube anything.
Maybe this grease needle will come in handy for something else.
Old Jul 16, 2007 | 10:15 PM
  #40
Bark's Avatar
The needle will come in handy for doing what Deesil is talking about. Read some prior posts on it I just havent been brave enough to puncture the rubber boots.
Old Jul 17, 2007 | 03:03 PM
  #41
Deesil's Avatar
Muted User
"brave" is running the stock ball joints with the four year old grease in them.
Old Jul 20, 2007 | 11:30 AM
  #42
HayHauler1's Avatar
Dealers....
Feeling your pain.....
I took my truck to the Astrodome area dealer for my forth oil change at 23k miles. (My fifth is free) I told them to lube my front drive shaft like it says in my owner's manual. The service writer told that there were no lube points on the front shaft. I told him that I know there is and to have the tech lube it THIS TIME, because they hadn't on the last 3 oil changes and their manual says that it should be done at each oil change. Anyway, long story short, the tech that filled out the 27 point inspection sheet that they leave in the truck, said that he greased the ball joints, but there were no lube points on either of the drive shafts. I have printed out the picture of the drive shaft lube point and the pic of the NAPA tool and I will take it and show them how and where to lube the front shaft.
I just can't believe that there is something in the owner's manual that they argue does not exist.
Oh, well, after the next oil change (read FREE) I will change my own and grease the front shaft with my own NAPA grease gun adapter that I bought the other day.
Hay
Old Jul 20, 2007 | 11:48 AM
  #43
3500eh's Avatar
where is the caradn joint on 03. i really have no clue. want to start doing my own service work that i can. doubt any grease nipples on my truck have ever been done. where are they?
Old Jul 20, 2007 | 11:58 AM
  #44
HayHauler1's Avatar
Look back at the first few posts on this thread. There is a link posted to another thread with pictures. BUT, I also read that there is no lube point on the '03 models later in the thread.
Hay
James Birdsong
Apr 22, 2011 10:14 PM
ButchCassidy
Dec 30, 2007 10:02 AM
CACalomino
Jun 1, 2007 11:13 PM
bigfish5
Mar 20, 2007 08:17 PM
Almond Pale Ale
17
Jan 25, 2007 08:21 PM
