2 lube points
Old May 16, 2007 | 06:19 PM
wreedCTD's Avatar
2 lube points
The manual says i have 2 lube points on my 06. The front drive shaft and the outer tie rods. Can someone post pics of what i need to lube and give me a quick explanation on how to do it. I have decieded to to all my own oil and filter changes so hopefully my truck dosent see the dealer for a long time.
Anything else i need to do please post that also.
Old May 16, 2007 | 08:32 PM
djbikeman's Avatar
Check this thread out for the driveshaft.
https://www.dieseltruckresource.com/...d.php?t=127834
To lube the tierod ends you just need a grease gun with a zerk fitting. push the fitting on and pump grease in until the old stuff starts coming out. clean up the old grease and your done.
Old May 16, 2007 | 08:36 PM
wreedCTD's Avatar
i think i found the out tie rod grease point. does the gun connect to it and squeeze the grease into the tie rod end? isnt what i a squirting grease into a ball joint?
any thing else i need to do?
Old May 16, 2007 | 08:37 PM
wreedCTD's Avatar
also what kind of grease should i buy from the auto parts store to lube it with?
Old May 16, 2007 | 08:59 PM
$oC@l CTD's Avatar
I like the Mobil 1 Fully Syntetic grease...it's pink in color...seems to work great. You got BOTH tie rod end fittings right? There is one on each side...those and the drive shaft fitting are the only ones that we have on these trucks
Old May 16, 2007 | 09:54 PM
PourinDiesel's Avatar
Mobil One works good but when it sits a while it starts to liquify. I wont be buying anymore needless to say.
Old May 16, 2007 | 10:18 PM
$oC@l CTD's Avatar
Really? I have never experienced this...what do you reckon causes it...what do you use?
Old May 17, 2007 | 10:32 AM
GSW's Avatar
GSW
I use the waterproof Green Grease. Good results on multiple rigs.
Old May 17, 2007 | 12:04 PM
HOV's Avatar
HOV
I use standard old lithium grease. It specifies which spec lithium grease to use in the service manual.
Old May 17, 2007 | 01:52 PM
DBLR's Avatar
Had the same thing happen to me last summer and I to will never buy it again.
Old May 18, 2007 | 09:41 AM
ASHNBAK's Avatar
Same here! I wonder if it seperates in use.
Old May 18, 2007 | 01:09 PM
t-boe's Avatar
I used the same stuff this morning. As far as the driveshaft, it's pretty easy if you get the driveshaft just right and use a grease needle. Took about 5 times moving the truck a little at a time to get the driveshaft in the right spot. I really didn't want to remove it.
Old May 23, 2007 | 04:56 PM
wreedCTD's Avatar
OK guys i got a new grease gun, some grease and i just want to make sure i am greasing the right thing since i have never done it on this truck.
i know its a horrible picture but its all i got.
my question is do i just connect the grease gun to that nipple and Squeeze!?
let me know. thanks!
Old May 23, 2007 | 05:05 PM
Yup........
You'll get the hang of it. Just make sure the grease is going inside the zerk (nipple) not everywhere else.
You'll know it when its happening right when you hear the seals "crackle"....thats the new grease breaking the seals and pushing out the old grease.
Dont forget your 06 has a greasable "eye" in the center of the cardan joint.
wreedCTD's Avatar
i bought the valvoline grease. is this stuff any good or should i get something else?
