3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
View Poll Results: Removed intake baffle or silencer ring?
Just intake baffle.
68.75%
Just silencer ring.
0
0%
Both!
31.25%
Voters: 16. You may not vote on this poll
Removed the baffle
Old Dec 18, 2010 | 01:23 PM
13ALPHA's Avatar
Removed the baffle
Well after reading on the threads about removing the silencer ring and baffle I decided to take out the baffle, waiting on the silencer ring for now. I was picturing a little air foil thing, but when I pulled this honking piece of foam out too it was crazy! That thing had to be blocking like 33% of the tube's cross section. I can't wait to see if I can hear a difference. Anyway, thanks guys for the info!
Old Dec 18, 2010 | 11:19 PM
got_soot's Avatar
Soot For Brains!
i only noticed a small difference when i pulled the baffle out!! when i took the silencer out that was a big difference and much happier..
Old Dec 19, 2010 | 12:33 AM
MTRK2002's Avatar
Someone post some pics and procedure for the silencer ring removal would be awesome...
Old Dec 19, 2010 | 10:39 AM
13ALPHA's Avatar
I did find one on here somewhere, it had good photos showing that you have to remove the front housing of the turbo them drill out those rivets. If I find it again I'll link to it.
Old Dec 19, 2010 | 10:41 AM
13ALPHA's Avatar
Here is that thread: https://www.dieseltruckresource.com/...r+ring+removal
This is for a 6.7L keep in mind, didn't see a truck in your signature. The process for a 5.9L is much simpler.
Old Dec 20, 2010 | 10:35 AM
Scotty's Avatar
Top's Younger Twin
There should be an egt reduction after removing the restriction/baffle.
Removing the silencer ring is more of a preference for a change in sound.
I swapped out my intake hose for a smooth bore hose with one of my old Scotty Air 5 intakes and saw 200F reduction towing. I put the factory box back on only because I have not succeeded in finding a competent fab shop here to make a coupler that can accommodate both sensors and not look like a monkey built it. These 6.7's respond well to getting air in and air out. Probably because they were choked so bad from the factory. JMO
Old Dec 20, 2010 | 12:47 PM
13ALPHA's Avatar
Thanks for the input. A little part of me says don't take it off, the engineer had it there for a reason, but what reason? More than just sound reduction? I read arguments about airflow, but also someone said that they had not seen any present in commercial applications, which if true leads me to believe it was just there for sound reduction.
Any one here seen the 6.7 with same turbo on other applications? Was the silencer ring present?
Old Dec 20, 2010 | 03:02 PM
cbrahs's Avatar
removing the silencer ring only increases the ever joyful whistle of the turbo which puts smiles on our faces but if you look at its design closely, it (when in place) guides the air into the turbo, remove it and there is turbulence around the outside edge which makes it less efficient. ya want more whistle, put on an aftermarket intake.
Ghost Ram
13
Nov 22, 2006 08:40 PM
05-6X6
Feb 14, 2006 09:47 AM
deere nut
Jul 5, 2003 12:18 AM
misterKTM
Apr 28, 2003 05:08 PM
