3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
6.7 deletes, does the engine oil stay cleaner?
Old Nov 7, 2010 | 03:32 PM
2006BLKMegacab's Avatar
im getting myself talked into doing the deletes on my 08 (if i didnt have a few speeding and seat belt tickets lately i would be done them already). the thought i had run through my head is that if the egr is disabled or removed does the engine oil stay cleaner longer like my thought process says it should?
thanks in advance guys
Old Nov 7, 2010 | 04:06 PM
Ahab's Avatar
I just did my second oil change after doing the full deletes on my '09, and finally my oil did not turn black by the time it ran down into the pan.
I have about a week on it so far, and it is still golden brown.
It certainly makes me feel a lot better seeing the oil stay clean a lot longer.
There are many, many reasons to delete, with cleaner oil just one of them.
Scott.
Old Nov 7, 2010 | 05:45 PM
sabercat's Avatar
Mine seems to be cleaner
Old Nov 7, 2010 | 06:34 PM
klx650a2's Avatar
Mine stays clean for 2,000 miles after an oil change.
Old Nov 7, 2010 | 07:40 PM
Blake Clark's Avatar
Yes it will be somewhat cleaner.
Old Nov 8, 2010 | 08:02 AM
MikeyB's Avatar
My Dad said his oil stays clean longer now since doing the deletes.
MikeyB
Old Nov 8, 2010 | 08:50 AM
Jim W's Avatar
Yes, the oil will be cleaner you will have less fuel and soot in the oil with the deletes.
I have attached a copy of my latest oil analysis from a Cummins Lab for you to review.
Jim
File Type: pdf
Old Nov 8, 2010 | 02:02 PM
Lil Dog's Avatar
Far cleaner.. with the OEM system the oil was sooty black as soon as you changed it. After the deletes I have the oil I wanted, nice and brown with little soot in it.
Old Nov 8, 2010 | 03:16 PM
mega-engr's Avatar
"California Style"
I did my first oil change after the deletes recently and it is all ready much cleaner! I love it. And, it doesn't increase in level now due to dilution.
Old Nov 8, 2010 | 06:14 PM
Lil Dog's Avatar
Good point..
Old Nov 9, 2010 | 10:02 PM
thank you all for the great information, if i can keep my foot out of it and my seat belt on i'll be deleteing asap
Old Dec 21, 2010 | 12:29 PM
Mike Holmen's Avatar
The Guru
The oil gets dirty from the late firing injection event on the 6.7L The H&S tuner removes that event and there is less fuel build-up in the crankcase. I have 8000km on my oil and it almost as clean as the day it went in.
With the H&S programmer you can remove/unplug the egr, the air horn butterfly, egr cooler valve. I still haven't removed my egr or my egr cooler. Been waiting for my custom air horn to get done, so I can do a bunch of stuff all at the same time. I'm just going to use a 2nd gen 24V exhaust manifold and just remove my egr cooler/6.7 exhaust all as one unit. Typically the aftermarket exhaust systems for the 2nd are cheaper than the 3rd gen stuff. I'm going to run either a GT3788R or a S366 on the 2nd gen manifold. Been finding that these VGT turbos are awful on the 6.7L
rebel102285
Sep 24, 2014 08:29 AM
shlen
ABDTR #5
Oct 19, 2013 10:05 AM
greenrig
Oct 3, 2009 10:29 AM
MyDieselStinker
Jul 29, 2009 03:05 PM
Bobcat698
May 6, 2007 08:21 AM
