3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
max rail pressure on a 6.7L
Old Oct 27, 2008 | 09:50 AM
Dwitt0187's Avatar
im trying to do something does anyone know how much rail pressure is max on a 6.7l. does anyone have a rail gauge on a 6.7 and it so how far does your gauge read?
Old Oct 27, 2008 | 06:21 PM
Dwitt0187's Avatar
bump........
Old Oct 28, 2008 | 12:07 AM
XLR8R's Avatar
Rumor mill spec'd ~30Kpsi IIRC.
Old Oct 28, 2008 | 12:55 AM
BigTXDually's Avatar
When I went to Cummins school on these engines they said that they ran around the same RP as the 5.9 CR engine. From my experience in monitoring the RP at different operating levels they are prety much identical to those of the 5.9 CR and as far as gauges go one of my customer purchased a DiPricol RP gauge from me for his 5.9 and told me that it also works on his 6.7. That is which way I would lean if it was me. Hope this helps you out.
Old Oct 28, 2008 | 08:23 AM
Dwitt0187's Avatar
thanks guys
Old Oct 28, 2008 | 05:57 PM
Dodgezilla's Avatar
I heard they dropped the RP a lot for the 6.7s....
Old Oct 28, 2008 | 07:02 PM
bluechrome's Avatar
I heard Rp is much higher for the 6.7's. Also the injector tips are much better than the 5.9's
Old Oct 28, 2008 | 11:20 PM
bob4x4's Avatar
I have seen 27500 on a stock 6.7.
The injectors and tubes are S/S,the rail is also larger and stronger
Bob
Old Oct 29, 2008 | 09:30 AM
qzilla's Avatar
I have seen 28,300 on the 6.7L. I have seen 31K with the rail capped.
If someone used a RP gauge from a 5.9L then they would think the RP is lower. The fact is that the sensors are mapped differently in the 6.7L application.
Old Oct 29, 2008 | 09:43 AM
Dwitt0187's Avatar
so will the 6.7 sensor read to 31000 unlike the 5.9 only reading to 27500
Old Oct 29, 2008 | 11:08 AM
Dodgezilla's Avatar
Thanks for the info qzilla. I thought it would be strange to have lower pressure and more power at the same time....
Old Oct 29, 2008 | 11:31 AM
cquestad's Avatar
I would like to know more about the 6.7 rail sensor?
Same size just different output?
Old Oct 30, 2008 | 10:11 AM
qzilla's Avatar
Same exact sensor but, it is scaled differently.
Located on the back of the rail just past #6 injector line. Sort of a pain to get to but, other than that, just like the 5.9L.
The biggest difference is the additional pressure and the relief valve.
Old Oct 30, 2008 | 10:12 AM
qzilla's Avatar
It will function fine but, in no way will it be accurate.
12valve
38
May 6, 2009 08:26 AM
5.9Excursion
Mar 13, 2008 10:56 AM
wyocat
Sep 3, 2007 01:49 PM
Dodgezilla
Jul 11, 2007 07:19 AM
Zino
Aug 15, 2003 10:14 PM
