Took the Plunge
Old Dec 15, 2006 | 12:09 PM
BuildingBoost's Avatar
Too Much to thinks about...Suggestions.
Well after a couple months of reading and wanting, I decided to pull the trigger and begin the journey.
Round I: (finished)
Built Tranny (Suncoast) Incl. - Billet Flex Plate, Input Shaft
Fass 200
Silver Bullet 62
ATS Manifold
Hogg Exhaust
S&B Intake
BDTD w/Outlook
Round II: (planned) Please share any suggestions on additional Mods!
Dr. Performance Predator Box Stage III
II Modified CPE
II Injectors
Head Studs
Fire Rings
II Twin Turbo
Water/Meth
Old Dec 15, 2006 | 01:13 PM
morkable's Avatar
You will like that predator, very nice pressure box, I will probably be putting one of those on my truck next spring, everything you have planned looks good, I would think about going to a different box than the bd, the ppe seems to work really really good with the dr performance unit.
Kevin
Old Dec 15, 2006 | 01:20 PM
masonic-dodge's Avatar
Don't run a pressure box and a modded CP3. You need to deside which one of the 2 you want the most. Both the box and the pump raise fuel rail pressure just fine, but when you put then together it adds too much pressure for the inturnals of a common rail injector.
CRIS
Old Dec 15, 2006 | 01:59 PM
morkable's Avatar
The nice thing about the dr performance is that it ramps up the pressure,, starting a 0, whereas boxes like the mp8 or the edge ez, start at 10 and then ramp up really really quickly. I am not worried about running the dr performance with a upgraded cp3,, but I would be if I was running one of the other boxes
Kevin
Old Dec 15, 2006 | 04:59 PM
What type of "stack" would you suggest?
Old Dec 15, 2006 | 05:07 PM
morkable's Avatar
I like my present stack, but I am going to add the dr performance predator. There are some guys running the ppe with the dr and it works awesome
Kevin
Old Dec 15, 2006 | 05:22 PM
BB
It doesn't matter how the pressure build it pressure or how fast. It is the total pressure that matters If the box builds pressure slowly or fast it still builds pressure and with a modded pump the injectors(insides) can't handle it for long. I know what 2 bad injectors sound like and that won't happen again.
I have a modded pump, but I took the box off.
CRIS
Old Dec 16, 2006 | 08:38 AM
Boz007's Avatar
TST with either the BDTD or Smarty.
bennydodge
Feb 19, 2008 07:21 AM
sumner
May 17, 2006 11:41 PM
texasredrider
Jan 26, 2005 09:47 AM
BAJA MAN
Jan 1, 2005 10:43 PM
msurf
14
Dec 31, 2003 10:46 AM
