Super Phat Shaft 62 and stock exhaust
I am looking at a used SPS 62 off of a 04. I need to know what adapter or downpipe I need to make it work on my 06. Thanks for any and all help.
06 DIESEL
06 DIESEL
Just like everyone else has said, it should just bolt right up. If the truck was an 04.5 you might see if they have the boost resistor plug. If the truck was just an 04, then they will not have the plug and you will need to get one. But as far as the downpipe, the one you have is fine.
madhat's monkey boy...
You could keep the stock boost control solenoid hooked up to fool the ECM. I have mine in a ziplock bag ziptied out of the way. Sometimes those resistors are not as good as the real thing for preventing codes. Everything is a direct bolt up and the only mod you will need to do is your stock cast iron elbow will have alignment pins that you need to remove. I just ground mine off, it was easy. Get new turbo mounting studs and nuts with the gaskets too when you order them. The studs are a different length compared to stock.
4969joes
02-22-2010 01:22 PM
Smkn600CTD
33
05-28-2007 09:50 AM
PourinDiesel
05-01-2006 06:15 PM
cliffs03hd
11-24-2005 03:29 AM
PourinDiesel
08-29-2005 01:25 PM
