smarty vs smarty beta
Actually the stock turbo would give you less smoke (except maybe at WOT) because it spools so much quicker. With 4.4 and the stock turbo on mine it would actually clear up completely under WOT. Mine smokes like crazy now with the larger turbo if RPM's are under 1900.
I know what you mean by embarrassing. If I give it any significant throttle under 1900 RPM it can and will black out a 4 lane highway.
When I do WOT in those cases, it also doesn't clear up. It stays hazy. I suspect the stock CP3 and sticks under the added pressure from 4.4 can put out a little more fuel than the stock turbo can clear up.
It would probably help too if I ran a boost fooler. As for Smarty levels, I've never run anything higher than 5, even after I got a built transmission, since I still have stock fueling. I've never run the wild program either.
jrussell
37
May 31, 2007 08:04 PM
ramtd02
99
May 18, 2007 11:55 AM
Timinva
140
May 4, 2007 12:15 PM
RyeThomas
40
Apr 20, 2007 10:12 PM
OT-OF-Here
Apr 20, 2007 08:11 PM
