Slipping My Sbc Dd3600
Old Jan 25, 2007 | 12:53 PM
  #46
D.Wiggs's Avatar
Originally Posted by WhiteSport600
455/50??? That's a super-single isn't it?? That's gonna look
Yeah, they are Super Singles!
I was thinking of throwing two of those bad boys on the back and have the outside tire stick out about 16" on each side!
Old Jan 25, 2007 | 12:57 PM
  #47
WhiteSport600's Avatar
LMAO!!! talk about rock chips!!!
Old Jan 25, 2007 | 12:59 PM
  #48
D.Wiggs's Avatar
Let's see, that would make me about 10'4" wide in the rear, tire to tire!
Tell me that wouldn't be funny!
Old Jan 25, 2007 | 01:04 PM
  #49
I bet the cops will love that! Not to mention you wouldn't have to worry about somebody side swiping the body of the truck You should do it for a sled pull... I wonder if the driveline would hold the up??? Axles would..."fall down, go boom"
Old Jan 25, 2007 | 01:05 PM
  #50
D.Wiggs's Avatar
I would be doing an axle swap with a Kenworth W900 as opposed to another Dodge!
Old Jan 25, 2007 | 01:08 PM
  #51
OH BOY!!! Now you've lost your mind!!!
Old Jan 25, 2007 | 01:11 PM
  #52
getblown5.9's Avatar
Wiggs, can you 3rd gen guys do the 2 wheel low kit? i dunno if you have a central axle disconnect or not...but the second gen guys with CAD put a vacuum switch in the line so you can control whether the front end locks in 4wd low or not.
if not, then you could always get the dyna-trac free spin locking hub kit. leave them unlocked and put it in 4 low for a 2wd low...its expensive but given Opti's past mods...i don't think it would matter LOL
Old Jan 25, 2007 | 01:13 PM
  #53
We don't have the option of the axle disconnect, ours just disconnects at the T-case. You'd have to do the lockouts, but then he couldn't run the pretty centercaps on his Alcoa's
Old Jan 25, 2007 | 01:15 PM
  #54
D.Wiggs's Avatar
Think about it. Optimus's specs would be:
Front Axle AAM 9.25 (8,000lb. Max-or whatever it is)
Rear Axle AG690 (69,000lb. max)
Old Jan 25, 2007 | 01:16 PM
  #55
D.Wiggs's Avatar
And we do NOT want that!
Old Jan 25, 2007 | 02:50 PM
  #56
South Bend Clutch's Avatar
Vendor - Former Vendor
Oh, yeah... I read about that. Sprung hubs in the clutch discs, should help alot, but I'd worry about longevity of the springs in sledpulling applications. I've seen dual disc racing clutches w/ sprung hubs and springs laying in the bellhousing! They should be fine if you're not shocking them too often though. It would be nice to have a quiet truck again! I start off in 2nd w/o throttle every time, just like a stocker... I wonder if your wheels and tires are why you can't do it?
This is exactly why it has not been done in the past, for fear that the spring designs would not be adequate. The spring assemblies I am using are the same that are used in freightliners. I don't think we will have a problem with longevity/strength...
Peter
Old Jan 25, 2007 | 02:57 PM
  #57
D.Wiggs's Avatar
Peter
You da man Pete!!!
Old Jan 26, 2007 | 09:25 AM
  #58
JohnInNH's Avatar
Pete... Say thanks to Woody and Mary for me... Can't wait to get this puppy in!
(Invoice #58018)
CapnRam
May 22, 2010 06:20 PM
DIESELWRKS
Oct 11, 2009 10:32 PM
03dodgeoffroad1
14
Mar 1, 2009 09:04 PM
O.T
May 28, 2007 09:09 AM
francis212
14
May 18, 2006 09:46 PM
