P0148 code on Quadzilla Standard Box
Old Apr 30, 2006 | 06:01 PM
Batts's Avatar
Has anyone had any experience with this? Should I be concerned? Is it still okay to drive or can I damage the engine?
Sorry guys but I just don't like the idea of my engine warning light being on!
Cheers,
Batts
Old Apr 30, 2006 | 08:09 PM
texaspower19's Avatar
i get that code every now and then it takes about 4-6 starts for the light to go away by its self.
Old Apr 30, 2006 | 10:02 PM
dodgezilla04's Avatar
mine did it alot, after a while, it progressed to shaking, smoking, knocking, and just running like CRAP. dealer reflashed the ecm last thursday.
it did it with the quad standard, race, and stock. so I dont think it is quad related. hasnt done it since the flash.
Old Apr 30, 2006 | 10:27 PM
qzilla's Avatar
Somewhere at some point you ran out of fuel pressure. That is fuel pressure on the low side. The 0148 will almost never cause the truck to run any different, but it will annoy you. The light will go out after a few starts unless the original issue persists.
Could be dirty fuel filter, weak lift pump, or who knows. I would not fret too much unless you can continuously get the error.
Usually it takes a pretty good load to get a stock truck to do it, but when you start demanding more fuel it can be more prevelant.
Old May 1, 2006 | 04:16 PM
BRayls's Avatar
time for a good fuel pump. the stock one is junk.
Old May 1, 2006 | 05:41 PM
Batts's Avatar
Thank Qzilla..
The light went out this morning and has not come back on since.
Very relieved.
Cheers and thanks for your time
Old May 1, 2006 | 10:17 PM
change that L/P before it gets costly. I put a BD lift pump kit on mine last weekend. it runs great with the quad race on full, before it would slowly fall on its face
Old May 2, 2006 | 06:07 PM
The_Mudhog's Avatar
P0148 Code with Quadzilla
I have gotten the dreaded P0148 Code twice now. I cleared it once and let it cycle itself out the second time. Does anyone think that I need a BD Lift pump Kit? 04.5 Dodge Ram 3500 Non Dually H.O. 610 with the Xzillaraider 130HP. Gary
Old May 2, 2006 | 06:15 PM
BRayls's Avatar
yes ,I do. with just an ez you can drop to 0 psi on the stock one.
Old May 2, 2006 | 09:58 PM
you like the way it runs with the zilla on 130 now, just give that cp3 the fuel it needs and the fun really begins. mine used to begin to run out of steam about 2800 rpm after a sustained WOT blast, but not anymore. more power down low too since it always has fuel, just returns what it doesnt need.
i checked the return fuel line after the cp3 with both the stock lp and the BD after a few miles of driving, warm with the stocker and cold with the bd, definately getting the cooling/lube it needs now. any l/p kit is better that the factory setup.
Old May 2, 2006 | 10:32 PM
Batts's Avatar
Advice on L/P?
Which brands do you guys suggest and what are the approx costs?
Cheers,
zBatts
Old May 29, 2006 | 07:03 PM
The_Mudhog's Avatar
The Right Lift Pump
I found the BD Lift pump part number BD1050226 for $240.00 Free shipping on www.xtremedieselperformance.com I don't know if this is the right part?
Gary
Old Jun 2, 2006 | 01:37 PM
The_Mudhog's Avatar
P0148 code
My truck is at the Dealership now. I don't know what is wrong but the dreaded P0148 Code came up again and my truck is running like CRAP. It studders, and kicks it even stalled when I got to the dealership. I will probably will replace the Lift pump but I don't want to Void out my warranty. I think that I will go with the Mopar lift pump. Part number 5175539AA. I don't think that I want to cut open my fuel lines. Does anyone have any feedback on this. The dealership said that I wouldn't have to cut my fuel lines for the Mopar one. They told me its just plug and play.
Gary Ferguson
978-833-7626
Old Jun 2, 2006 | 02:35 PM
Spooler's Avatar
Just had it done to my truck. Runs noticeably better. 10 PSI at idle.
smncrst
Oct 27, 2009 09:10 PM
jon05ctd
Dec 31, 2006 10:04 PM
nofender
Jul 13, 2006 02:26 PM
inline6power
Jul 7, 2006 11:37 PM
StealthRam
Sep 21, 2005 02:27 PM
