lift pump
Old Dec 18, 2008 | 02:52 PM
sterling's Avatar
lift pump
I was thinking to use a set of 12 volt electric fuel pumps made for gasoline engines to pump diesel from the fuel tank to both diesel engines in my boat .
Are the gasoline pumps going to survive diesel oil ?
Or am I better off with so called diesel pumps ?
I found that the gasoline pumps are much cheaper ,or is that for a reason?
thanks A.J
Old Dec 18, 2008 | 03:34 PM
rip 112's Avatar
Honestly I would look at the Holley Blue pumps, they can handle gas or diesel...For the price they should be fine...not too expensive...
Old Dec 18, 2008 | 03:59 PM
kantdrive55's Avatar
DTR Advertiser
What type of fuel volume do you need? What motors are you running?
Old Dec 18, 2008 | 04:07 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
mount them low so they have a good head, and remove the brass screens in the pump housing, (they can get clogged easily with cold fuel) then shim the regulator spring with at least a .040" shim washer to provide good psi, no problem. I use the larger housing "Black Holleys" under my truck and they hum along endlessly without issue cold or hot.
Old Dec 18, 2008 | 04:22 PM
sterling's Avatar
I have two Yanmars 6LY2A,s with 440 hp/at 3300 rpm a piece ,these are 5,8 L 6 cilinder inline 2 valve ,s with a line pump,they have 880lbs/ft a piece ,and use 90 Litre /hour (24 gallon/hr) full throttle.
I am going to turn up the fuel at the pumps and hope to reach about 500 hp a piece ,so I guess 28 gal/hr ???
thanks A.J
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
