intake baffle removing?
I have a 06 auto. And i was reading on here and seen that some of you guys are taking out the baffles in the intake tubes . what would be the easiest way to do that? I looked at it and looks like it doesnt come apart to easy. Other than busting it in to pieces. any advice.
thanks Eric
thanks Eric
I removed mine on my 03, can actually hear the turbo some now. If your's is the same as mine it is glued together on the one end, I used a utility knife to split it at the seam. You have to really take your time so you don't bread anything. The baffels just slide up out and you epoxy it back together. Do a search on here, there is a post that has pictures somewhere.
13bdarren
Mar 14, 2009 09:19 PM
05-6X6
Feb 14, 2006 09:47 AM
