"how-to" for oil bypass
Old Apr 20, 2008 | 08:18 AM
tristan21's Avatar
ok I know I ran across a thread a while ago on a DIY oil bypass system but I search and can't ever find anything. Anybody know that link. I know the amsoil is fairly cheap but I have the resources to build my own and alot of the hose and fittings already. Its mostly just a filter a bracket and lines but I dont know what to buy?
Old Apr 20, 2008 | 08:31 AM
Totallyrad's Avatar
Is this the one? https://www.dieseltruckresource.com/...light=oil+pass If you look into the thread there is a homemade bracket and several mounting locations shown.
Old Apr 20, 2008 | 09:34 AM
tristan21's Avatar
Thanks for the link rad man. It wasnt the one I was looking for but it helps.
Old Apr 20, 2008 | 12:56 PM
Syndicate's Avatar
DIY spin on system - Baldwin OB1305 filter head w B50 or B164 filter. I had my own hoses made at the local hydrolic shop and used an Amsoil valve cover cap for the return line. Very easy Very simple. Seems to work just fine.
Old Apr 20, 2008 | 01:26 PM
tristan21's Avatar
dont suppose ya took pics of it. Are those the only part #'s I need? Is it 2 mic filter? What preassrue hoses? Very low I would assume.
Old Apr 20, 2008 | 01:28 PM
tristan21's Avatar
What do you figure you spent? Thanks
Old Apr 20, 2008 | 01:54 PM
RMCBRIDE's Avatar
Bypass Filter
Hey Tristan21,
OilGuard has a new setup for the Dodge Cummins. Go to their web site and select 5.9 Dodge Cummins. The new part number is (EPS-20 DCE). This kit has the bracket and all of the fittings. All you have to do is install it on your truck. I run an OilGuard on my truck and have had no problems with it.
Old Apr 20, 2008 | 04:51 PM
carl48's Avatar
the hoses syndicate mentioned are good up to several thousand psi they are cheap and will not wear into mount the filter on the frame or fender, i solder a copper disk in a 1/8" swivel and drill a 0.065" hole in it then screw that into the top of existing filter housing cummins says not to exceed 0.078" the filters i use were made for larger trucks and equipment and the orifice is to large i think the one he suggested uses a 1/16" if it does it is perfect run the bypass filter until it clogs up the dirtier a filter is the better it filters
Old Apr 20, 2008 | 05:07 PM
AH64ID's Avatar
I am not sure about the B50, but the B164 is only 15 microns absolute, so not bypass quality.
Old Apr 20, 2008 | 05:16 PM
Syndicate's Avatar
B50 is a shorter version of the B164. Many people are using them in a DIY by-pass setup. True the dont filter as well as the TP filters do but they do filter much better than just a full flow stock filter will. I am using one simply to double the kms between oil changes. The B50 has a built in restriction (1/16'') so no need for the copper disk. I think I have approx$55 bucks in the setup plus the amsoil cap.
Old Apr 20, 2008 | 05:54 PM
bdewey's Avatar
ther has been a guy on ebay that sells the b50 filter with filter head and hose and fittings for less than $50 that is where I got mine and has been great. Extended oil changes out to 10,000 with good reports through Blackstone Labs. Did search under ebay for "oil Bypass"
Old Apr 20, 2008 | 06:34 PM
matego's Avatar
madhat's monkey boy...
Check these things out. Centrifuge filters do a excellent job of removing soot at a sub micron range. I have the Centriguard but did not install it yet. Spring and Summer usually have me tied up so it may be a while yet.
https://www.dieseltruckresource.com/...spinner+filter
Old Apr 20, 2008 | 10:03 PM
carl48's Avatar
i do not like to mount a by pass filter on the motor the vibration is to much i am going to try a centriguard also . the only place that i can think of to mount it is on the headache rack to make it work properly , i have several by pass filters mounted there it does not look bad and is easy to service i think i can go in the 2ond oil return plug and not drop the pan
Old Apr 20, 2008 | 10:05 PM
AH64ID's Avatar
But you can buy a full flow with the same ratings (Amsoil full flow are 15 micron absolute), so its not really a bypass (Amsoil bypass is 2 microns absolute)... its a full flow filter getting bypass flow... I am not sure that 15 micron rating is warrant enough alone to double your kms on the oil, I guess it depends on the oil, and the TBN.... (On my gasser I only put 8K on Amsoil this last 12 months, and the analysis was perfect and if I hadn't done a TBN test I would have run it another year, but the TBN was at 1.4 from time)....
Old Apr 20, 2008 | 10:12 PM
Syndicate's Avatar
From what I have read the B50 filters at 2 mic @ 98.75% so that would mean 74 out of 75 particles get filtered out. Sounds good to me. I have had it on now for 3-4000 kms so far. Im goin to change the oil soon. On the next oil fill I will send in some samples to monitor things.
