Help with speed limiter and shift points
Old May 24, 2006 | 06:49 PM
Leon441's Avatar
I currently have TST and run it on 4/4. I want a box to stack on that will not cost a fortune and get rid of speed limiter and give me the ability to change shiftpoints on my automatic tranny. I'm told the new superchips box will do this. Does any body know how well they work on 2005 truck.
Old May 25, 2006 | 04:27 PM
Leon441's Avatar
No One has any ideas?
Old May 25, 2006 | 08:39 PM
Dodgezilla's Avatar
I believe the Superchips for the Cummins is pretty new so nobody has tried it yet. Looks like it's your turn to be the guinea pig....
I don't think you get the ability to change shift points with the Superchips or Hypertech boxes made for the Dodge trucks. Something in the computer won't let them do it....
There are plenty of boxes you can stack with the TST though....
Old May 25, 2006 | 08:48 PM
CButler610's Avatar
I believe Dodgezilla is correct. The 48RE trans in our trucks is just not that sophisticated to do this, even though aftermarket software actually is. It really comes down to a valve body upgrade. This will definitely alter your shift points if you are in the throttle. Normal driving will be the same. Almost the best of everything.
Old May 25, 2006 | 09:30 PM
Dodgezilla's Avatar
In case you haven't noticed, I'm always correct!
In my mind anyways....
Old May 26, 2006 | 03:49 PM
Leon441's Avatar
I have a Suncoast valvebody and at WOT it shift just short of the red zone of tach. I find that the truck actually runs faster if you lift off throttle a little to allow it to shift early. I really need to do the maual lock up modification but figured the same box that disables the speed limiter might do some of the other stuff.
Old May 26, 2006 | 05:30 PM
no_6_oh_no's Avatar
BD makes the only top speed eliminator I know of but it will not take away the TQ management and defueling that is built into the ECU. You cannot run foot on the floor with these new trucks and get full fuel until you get some speed up. A TC, VB, and learning the TQ management will get you what you want.
Old May 26, 2006 | 06:34 PM
Dodgezilla's Avatar
The top speed eliminator from BD Power does eliminate the defueling in my 03! She slams into gear if I hammer it. Ask AK RAM. He gained 2 tenths in the quarter mile with it.. His is an 03 SO too...
Old May 26, 2006 | 07:35 PM
masonic-dodge's Avatar
no 6 oh no-
Not all 05s defuel, I can build any amount of boost I want at the line and it will not defuel I guess I'm just lucky. As for a BD box, it will fix defueling problems on 03+04 but on the 04.5 and newer it will only help with the top speed.
CRIS
Old May 26, 2006 | 09:20 PM
no_6_oh_no's Avatar
The 03's don't have any TQ management or defueling to speak of. The only limiting on them was the top speed. The RAD will work on the 03 but not the 04.5 and up because the electronics are totally different. You cannot compare the 03's to to the 04.5's to the 05's etc. The ECU's are all different and have different programs loaded that are not compatible. The 06's have 10,000 more parameters to handle all the new stuff and the EB. Even in the compatible ECU's the flashes change how things work. I don't ven want to contemplate the 07's!
The early 05's react a whole lot different than the late ones. Mine is a late 05. It defuels under 12 psi of boost, it defuels at WOT, defuels on shifts. At 5 mph I can roast the tires off, at 0 it will not move off the line or pull thru the brakes.
MasonicDodge, are you staying that you can stand on the throttle and the brake and the truck pull thru the brakes, spin the tires and rev over 1200 rpms? What is your truck's build date and what have you done to get it to do this? C'mon give it up so the rest of us can play too?
Another solution would be give Dave Goerend a call. I have it on good authority he has a build that will eliminate a lot of these annoying problems.
Old May 27, 2006 | 05:38 AM
Dodgezilla's Avatar
The 03s with the 47RE suffer the most from torque management and defueling! Come on by and I'll show you that the box works for me...
Old May 27, 2006 | 07:45 AM
Billy Ram's Avatar
I can bring my 04.5 up to any boost at the line. Usually about 20psi if the track is in good shape and when I leave it goes instantly to 42psi. My tranny shifts at 3000rpm and doesn't defuel.
I have a friend with a 05 that is identical to the color to my 04.5 and his torque management won't let him build much boost at the line and he is having a time getting his tranny to shift like he wants.
Old May 27, 2006 | 12:40 PM
No 6 oh no
I have no defueling issues at all. I can launch at any boost I want but I don't go over 20psi so I won't hurt my tranny.
My truck was built 9/04 and I found another ECU that was built 4 days before mine was. It was on EBAY and came off a CTD that was totaled on the way to the dealer, so it only has the factory 25 miles on it
The other ECU is sitting on the floor in my garage saying "be nice to me some might need me one day"
CRIS
mcolectd
Jun 13, 2008 02:42 PM
jgiachino
19
Apr 24, 2008 06:29 PM
MoparRiggan
Jul 29, 2005 12:02 PM
mr T
May 20, 2005 12:51 AM
Dodgezilla
May 30, 2004 03:46 AM
