Edge EZ and trans shift points...
Old May 25, 2004 | 04:59 AM
Dodgezilla's Avatar
Anyone notice a difference in the way the trans shifts with the EZ hooked up? I've been whining about mine shifting too quickly through the gears for quite a while now. My dealer says it shifts just fine and I finally realized that it is because I pulled the EZ off before I took it to the dealer and without it, the truck shifts fine. Is the box supposed to change the shift points? I also found out that w/ the EZ and the 315s, if I power brake it, it won't turn the tires over at all. (No I don't do this often, I just wanted to try it once)
Old May 25, 2004 | 10:14 AM
BigBlue's Avatar
Have you had your computer recalibrated? If not, take it to the dealer and have them reprogram it for your tire size (you'll need the revolutions per mile for your size tire). Your tranny is electronically controlled and is told to shift at a certain speed. Might help your problem. As for power braking your tires, those tires rae really big and heavy and it's gonna take a hard power brake to spin em.
Old May 25, 2004 | 11:17 AM
Dodgezilla's Avatar
Well, the trans did it before the tire change and yes I have had it recalibrated for the 315s..... It shifts fine without the box hooked up..
Old May 25, 2004 | 01:51 PM
BigBlue's Avatar
Guess it's time to call Edge and see what's up. When you say it shifts quick, do you mean your in OD by 40 mph quick? Or it's just really quick in shifting gears?
Old May 25, 2004 | 02:56 PM
Dodgezilla's Avatar
The shifts are normal, they just happen too quickly. In other words, I'm in OD when I should just be getting into 3rd. Adjusting the throttle valve cable doesn't help either, it just gives me erratic shifts and harsh kickdowns. I have contacted Edge and they are trying to figure out why it would do this when their box supposedly has nothing to do with the transmission....
Old May 25, 2004 | 05:56 PM
BigBlue's Avatar
Man I don't know. Let us know what you find out.
Old May 27, 2004 | 12:22 AM
alltork's Avatar
Something is definitely wrong. I have very similar setup, edge box 315s now 37s, recalibrated speedo, auto trans. I don't have any problem turning rear tires into molasses even without holding brake down. How does it seem with OD turned off? Is it throwing any codes? Maybe tranny is slipping just enough to trip itself into shifting to early. Just trying to help.
Old May 28, 2004 | 04:56 AM
Dodgezilla's Avatar
Alltork, it feels like it's really close to turning the wheels over so if I had a 325 hp motor plus the box I'm sure it would do it too. Remember, mine is just 250 hp stock...
No codes either.
Thanks
Old May 28, 2004 | 07:36 AM
RickCJ's Avatar
The throttle valve cable will change the shift points. With the box on you pull out faster with less throttle, the trans will shift sooner. Try adjusting the cable a little tighter, 1/16" or 1 click at a time. I have mine set at full throttle the valve is full open. Shifts at 18 mph 28 mph 38 and lock at 48. Will shift at 3200 rpm wide open.
Old May 29, 2004 | 06:37 AM
Dodgezilla's Avatar
From a stop, if I mash the pedal, it will shift fine through all the gears. It's the part throttle shifts that are the problem. They have made the TV cable harder to adjust but I may get out there today and see what I can do.....
Old May 30, 2004 | 03:46 AM
MonkeyLips's Avatar
47RE...
Tron
Oct 30, 2008 01:35 PM
gorms
Jun 17, 2008 07:12 PM
MoparRiggan
Jul 29, 2005 12:02 PM
mr T
May 20, 2005 12:51 AM
67HotRod
Feb 17, 2005 07:51 AM
