egt not working properly
Old Aug 9, 2008 | 11:12 AM
#2 only's Avatar
gauge lighting
This is strange!
I hooked up my gauge and the light worked including the dimmer.
Now my light doesn't even come on nor does my test light at the back of the headlight switch,but the factory dimmer on the dash works.
Anyone else have this problem?
Old Aug 9, 2008 | 05:26 PM
#2 only's Avatar
Correction:
My clock and odometer lights work, but not my dash lights.
Old Aug 9, 2008 | 08:05 PM
#2 only's Avatar
does anyone know?
Old Aug 9, 2008 | 08:23 PM
pos dodge's Avatar
Check fuses. How did you wire gauge up? You saying gauge lights dont work nor the dash lights?
Old Aug 9, 2008 | 08:45 PM
#2 only's Avatar
I tapped into the back of the headlight switch.
The dash light or gauge light does not work.(same wire)
Old Aug 9, 2008 | 08:57 PM
pos dodge's Avatar
Ok. So is there power going into the switch and just not coming out for that wire. Or is there no power going into switch. Which colored wire did you tap into?
Old Aug 9, 2008 | 09:19 PM
pos dodge's Avatar
Ok
Ok i went and looked at the wire i used and since your truck is an 06 like mine i tapped into the orange/black wire. The test light should get brighter and dimmer when adjusting lighting.
Old Aug 9, 2008 | 09:23 PM
#2 only's Avatar
I thinkit was the orange/brown wire, but anyway it worked yesterday but not now.Also the dash lights quit, so something happened.All the fuses appear to be good.I hope it's not 1 of those things where you have to go to the dealer and reflash or something crazy like that
Old Aug 9, 2008 | 09:28 PM
pos dodge's Avatar
Nah it sounds like maybe the switch is no good. I would definitely check for voltage at switch. Do headlights work. What works and what dont?
Old Aug 9, 2008 | 09:32 PM
#2 only's Avatar
Here's what works
headlights,parking lights and rear cargo lights.
Here's what don't work
dash lights and dimmer function
Old Aug 9, 2008 | 09:39 PM
pos dodge's Avatar
Voltage
OK so if theres voltage going in and not coming out. I would say theres a switch problem. I would check all wires you hooked to gauges, maybe something shorted and caused that part of the headlight switch not to work. Just hope you didnt fry dash lights, cause i would imagine a new cluster would be pretty expensive. Im going to look at dodge service cd i bought and look at wiring diagram.
Old Aug 9, 2008 | 09:41 PM
#2 only's Avatar
I already looked and I might have to buy a new cluster!
Old Aug 9, 2008 | 09:51 PM
pos dodge's Avatar
Yeah
Yeah you were right its a orange/brown. Its dark here and i was using a flashlight looking under dash. I wouldnt rule out the switch. If you got a friend with the same truck as yours unhook your gauge wire from your switch and try his headlight switch. That might fix it. Cause if theres no voltage on that wire that means no voltage going to your dash lights. Just my .01
Old Aug 9, 2008 | 09:56 PM
#2 only's Avatar
I don't believe there's voltage going to the switch according to my test light.I wonder what might of caused a short after I had it working?
Oh well, Ive seen some crazy stuff out there.
max924
Nov 19, 2007 05:05 PM
srt20
Aug 8, 2007 11:20 PM
TJE
Oct 16, 2006 07:06 AM
trik396
Oct 14, 2006 06:33 AM
Pa outlaw
Mar 23, 2003 06:48 AM
