Chose fabtech over bds
Old Jan 2, 2008 | 07:39 PM
2007ctd's Avatar
I upgraded to bilsteins when i ordered the kit. Heres a pic of my old truck,kinda going for the same look with more tire tho.
Old Jan 2, 2008 | 08:36 PM
06CTDforAU's Avatar
Originally Posted by chipmonk
what would be the downside to off roading with spacers if you've upgraded to better springs and shocks?
Only reason I said that is because IF you are doing serious enough offroading that you have to disconnect the sway-bar, there is a chance that the spacer could "pop out" of place. Probably would never happen, but trying to seriously flex can do some weird things. If it were me, I would rather just have an 8" coil spring as opposed to a 6" spring with 2" spacers. But, you have to remember, these are 3/4 and 1 ton trucks; very few people actually take them off-road a lot. Unless of course you are one of the desert racing guys out east. And for the most part, they have smaller performance lifts anyways and they all come with coils.
Old Jan 2, 2008 | 08:59 PM
2007ctd's Avatar
I wont be offroading. Only offroad it'l see is on muddy pastures.
Old Jan 2, 2008 | 09:08 PM
06CTDforAU's Avatar
Then I wouldn't worry about it. You'll be completely fine. It's probably fine even if you are doing some moderate off-roading, but I like to be on the safe side. If all you see is muddy pastures, then go for it!
Old Jan 2, 2008 | 11:00 PM
Lsufan78's Avatar
your ride quality may suffer with the spacers (on top of the lift) due to the increased angle of the control arms.
Old Jan 3, 2008 | 12:01 AM
Hillbilly Delux's Avatar
i only have 2" spacers and im running 35-13.50-20s with 4.5 backspacing. had to do a bit of custom trimming. i would think 37s would clear ok with the extra 2.5 inchs from the fabtech. i had the fabtech 6" on an 02 ford supercrew. loved it except the factory ball joints wouldnt hold up
Old Jan 3, 2008 | 12:52 PM
chipmonk's Avatar
you need a minimum of 6" lift to assure yourself of clearing 35's with wheels that have 4.5" bs. 5" bs and a pos offset will assure you of clearing 35x12.50x17's with 4.5" lift.
norwegian Ram
Apr 2, 2015 03:40 AM
Z-MAN
13
Aug 31, 2011 03:41 PM
CODODGE2500MAN
Nov 10, 2006 08:21 AM
TxDiesel007
Nov 3, 2006 11:33 PM
bigfoot
Aug 14, 2004 02:22 PM
