How to chose an alternator?
Old Aug 24, 2011 | 08:47 PM
Z-MAN's Avatar
Red face How to chose an alternator?
I bought two new Gold Autozone batteries not too many months ago. They both died on me suddenly. Just replaced them both today with Optima Autozone. Alternator tested fine but I have a feeling that's not quite so. Already looking for a replacement alternator and I would like one that surpasses factory performance, is durable and it's not going to rust like the water or power steering pump which I replaced last year. I don't know to much about the market brands. Any suggestions and advice are welcome. Thank you Team Ram.
Old Aug 24, 2011 | 09:09 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
My suggestion is to have a local shop rewind it for you. Typically they are good the way they are. You have a load of accessories on it to want a heavier one?
There are limitations to alternators, especially at idle
Old Aug 24, 2011 | 09:25 PM
Z-MAN's Avatar
I don't have a specialized shop where I live and I wouldn't trust them anyways. I will do it myself but in the mean time I need one to swap it and drive it and if I spend the money I want a quality piece. I only have a power inverter that I use once in a while when I drive. And the radio, radar detector, phone charger and another charger. Truck has over 80k miles with this factory alternator. Pretty decent I would say. Thanks for the suggestion.
Old Aug 24, 2011 | 09:31 PM
06RAM2500's Avatar
https://napaonline.com/Catalog/Catal...+50022+2022078
$320 from the dealer, $30 core charge (and the $30 would've fixed mine as the only issue was a front bearing. )
Old Aug 24, 2011 | 10:23 PM
Polaraco's Avatar
Yer Velcome
Only 80K? They're good for 150K in most cases. But then again, this old and low mileage brings other problems.
I collect old Mopars. I have a 72 Dodge with 17,000 miles on it. Car is laiden with gremlins. Most recently it's the starter. I think you get my point.
I would run it for a while more. But as I said, put a volt meter on the batteries with it running to be sure it's not over charging. That would be a dround or a regulator.
A good way of telling there is a problem is with the head lights on. If they get dim at idle and real bright reved, chances are you have a charging system problem. But if they don't change much at all, then I suggest you get your monies worth out of it. Most decent auto parts stores can get one in a day if something happens
Old Aug 24, 2011 | 11:08 PM
Dr.Dizzle's Avatar
Hi Z-MAN,
I recommend you check out the alternators available at PA Performance. I have used their products and recommend them. You can see their products at PA Performance.com
Old Aug 24, 2011 | 11:17 PM
annabelle's Avatar
I bought a life time alternator from Autozone......has worked fine for about 25,000 miles.......tuned out my OME alternator was fine and I had to have the ECM reflashed. OME alternator had 275,000miles on it and it is still good.
Old Aug 25, 2011 | 08:13 AM
Totallyrad's Avatar
Out of curiosity.... what size inverter do you have and what do you run on it? Not that you can't have a run of bad rebuilds but usually bearings, brushes and regulators fail and when they do they take down the system and can cause other problems too.
Old Aug 29, 2011 | 08:28 AM
Uncle Ugly's Avatar
Best alternator out there I have found is made by a company in Western PA called Mean-Green.I had one on my other truck and it cured all the issues I was having at the time due to added load from things I placed on the truck.They may seem a bit pricey but are the best bang for the buck and are not a rebuilt unit.
http://www.mean-green.com/Home_Page.php
Old Aug 29, 2011 | 02:46 PM
Polaraco's Avatar
MMMMM Good Find. But the info is a bit conflicting. The list 03 to 09 alternators as 5.9
Old Aug 29, 2011 | 03:30 PM
xyzer's Avatar
Someday if needed I will do this upgrade.....**** good alternators!
https://www.dieseltruckresource.com/...rnator+upgrade
Old Aug 29, 2011 | 05:34 PM
maxwellp's Avatar
Talking
Eagle Auto Electric in CA. I put a 200 amp on a 96 snowplow truck. It puts out 182 amps at idle. They sell then on eBay. I have another one to go on the 01.
Old Aug 31, 2011 | 01:27 PM
sturgeon's Avatar
i've found car-part.com and ebay to be more than a fella needs..time permiting. Top-rated sellers on ebay really do what is needed to make it worth your while.
Old Aug 31, 2011 | 03:41 PM
AH64ID's Avatar
Have you verified the connections are all tight? If the + tie between both batteries is loose you can get some overcharging.
norwegian Ram
Apr 2, 2015 03:40 AM
5.9Excursion
Mar 13, 2008 07:08 AM
2007ctd
21
Jan 3, 2008 12:52 PM
CODODGE2500MAN
Nov 10, 2006 08:21 AM
TxDiesel007
Nov 3, 2006 11:33 PM
