Boost Question?
Old May 6, 2005 | 09:03 AM
03CTDCO's Avatar
Never said Pressure = volume.
Old May 6, 2005 | 09:37 AM
doug's Avatar
... with a fueling box added...
The turbo is already pushing more hot air than a stock set-up.
maybe maybe not. if the extra fuel produces enough pressure in the exhaust manifold to drive the turbocharger to higher boost pressures, then one of two things are happening: (1) the 'charger is pumping more air molecules into the engine, or (2) between zero and a small number of hotter air molecules are being pumped into the engine. remember that at very high turbocharger speeds, the compressor wheel does not efficiently compress air anymore, it just heats it up. this causes the boost gauge to read higher, and you to think you are getting more air.
remember that the boost gauge can't tell the difference between more molecules or just hotter ones. the goal is not to make your boost guage rise, it is to push more air molecules through the engine.
The elbow was to compliment this heat by allowing
a little more boost (psi)
the objective of additional boost is to push more air through the engine, creating higher combustion pressures and expelling more exhaust heat faster to keep your aluminum pistons from changing shape. if the turbocharger operates efficiently, then the boost elbow would allow the turbocharger to push more air through the engine, causing the needle on boost boost gauge to rise. If the turbocharger does not operate efficiently, then it does not push more air through the engine, but STILL causes the needle on your boost gauge to rise, making you think that good things are happening.
Hot or cold, boost is boost.
in a word, NO. no no no no no no no no no no!
I agree hot air is not efficient but we already
decided this was OK by adding our boxes and bombing our trucks.
No. Those who add power responsibly also consider the consequences of the extra heat, what causes it, and what to do about it.
Is the stock turbo out of its
peak efficiency range while running a box ? On the upper settings you bet.
maybe maybe not. efficiency of the turbocharger is not determined by the box or its settings, it is determined by how much heat the turbocharger ALONE adds to the air as it compresses it. The 04.5-05 trucks have a larger turbocharger, adjustable wastegate, and have a much better time accomodating a fueling box. the 03-04 turbocharger poops out at about 50-65 HP.
When I tow my 5er
later this month I'll see if the elbow actualy hurts or helps according to what my EGT's are running.
If I see my EGT's drop slightly with the elbow then I'm sold. If it turns out they my EGT rise with
boost then I will remove it. Towing 10K lbs on a hot summer day at 8-9Kft at 12% grade should
help me decide.
the use of upgraded intake and exhaust systems and EGT-aware driving can keep maximum allowable exhaust gas temperatures in check. But doing so is putting your head in the sand with regards to consequences you might want to ignore, namely the stresses on the turbocharger. the wastegate is there to prevent over-spinning the compressor, and when you defeat this safety device you may be compromizing turbocharger longevity, even if your EGTs are under 1400.
for the 03-04 trucks, the 'charger wastegate is set to the right point. you don't want the 'charger to spin as fast as it takes to generate 30 lbs of boost with this little charger. poor thing is just churning up the air and heating it up by that point, heating up its own bearings, accelerating wear, and getting ready to distintigrate. and you will be approaching FIFTY POUNDS OF DRIVE PRESSURE in the exhaust manifold just for the fun of watching your boost guage rise in response to hotter, not more, air molecules.
the best way to optimize the health and longevity of your turbocharger is to understand what boost levels it can generate efficiently. maximum EGTs is not a reliable way to to that. For the 03-04 turbocharger, this limit is in the upper 20s, as I have previously described. I haven't tested the newer 'chargers but expect there is significantly more margin.
sorry guys, for the old fueling box page. I'm hoping to do another market scan soon and update the matrix.
Old May 6, 2005 | 10:31 AM
Car_nut57's Avatar
Originally posted by doug
these guys are right for the most part.
above the upper 20s (psi boost) the little HY-35 with 9 square cm exhaust housing is just not capable of blowing more air. remember that your boost gauge cannot distingish between more air molecules and just hotter ones, and those high boost pressures mean something different than you might think.
if the 'charger could generate more boost efficiently, and actually deliver more air molecules to the engine, then higher boost would cool EGTs and allow you to fuel harder and gain performance.
I have measured the turbine drive pressure, compressor output air temperature and have captured peak compressor temp versus peak boost on this 'charger. by the time you reach 29 psi you are generating drive pressures in UPPER 40s, and blowing 350 degree hot air into the intercooler. all you're doing is stressing the 'charger and making your boost gauge think there is more boost air when it is really just hotter air!
doug, you hit the nail on the head with this. We have seen this same kind of data with our testing. One way to get more performance from this turbo and make it more efficient is with a Turbo Air Guide (TAG). We have test data that shows with a TAG the volume of air at a given boost pressure increases. One reason for this is the air is cooler entering the intercooler and more dense. If you look down this page you will find the information graph for the Cummins http://www.dieselpowerproducts.com/tag This larger volume of cool dense air is most significant when the engine and turbo are under load such as when towing.
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
