boost question
Old Dec 7, 2008 | 05:59 PM
buralcat's Avatar
boost question
hey guys. all the info on this site is amazing. quick q? i am running the Edge juice with att and an AEM cold air intake and i was wondering if the edge has a boost fooler on it or if i need to get one. what about an elbow (not sure what that is, if someone would like to enlighten me i would be greatful) thanks for the help guys.
Old Dec 7, 2008 | 06:10 PM
DUKCALN's Avatar
I believe your edge will boost fool up tp 40psi, over that you will need a Boost fooler. Boost elbow is an adjustable elbow of the wastegate air line, allowing you to get more boost by adjusting the air into the gate, kinda tricking the gate into thinking it has a small leak, thus building more boost.
Old Dec 7, 2008 | 06:58 PM
slimerept's Avatar
but you have a 2003, so it doesnt matter if its boost fooling or not, the manual wastegate opens and closes on its own. You should just get a bigger turbo, the stock turbo on a 03 is junk. Try and find a used one off of a 2004.5 and then change your manual wastegate over, along with that 20.00 ebay boost screw. you shouldnt spend much. Maybe 300.00
Old Dec 7, 2008 | 08:43 PM
Riflemanusmc's Avatar
Registered user
Man is correct. Zilla does the same thing on 03/04's. Will not send a code, but the only way you can FOOL the boost is by putting an elbow on it. 04.5 is a differant story. I have a NON adjustable "ELBOW" on mine. I hate the term "ELBOW" its a 90 deg fitting for C sake.........my .02
Old Dec 7, 2008 | 08:52 PM
DUKCALN's Avatar
04.5 turbo swap on an 03 works great. I know people who picked up 40hp. Nice thing is the 04.5 turbo cools better and can handle 50hp inj too.
Old Dec 10, 2008 | 12:58 PM
buralcat's Avatar
thank you for the help first of all. secondly, i need to get an 04.5 turbo (i.e. its bigger than the one i have correct?) do you mind explaining what the boost screw is? is the 04.5 wastegate also manual? just putting an elbow on it would work aswell? but the 03 turbo is junk right?
Old Dec 10, 2008 | 01:18 PM
cLAYH's Avatar
I have the Edge J/A on mine with a "boost elbow". The elbiow replaces the factory 90* fitting coming out of the turbo for the waste gate. The replacement elbow has a VERY small hole drilled in it vs the wide open fitting that comes stock. This delays the wastegate from opening and allows you to reach higher boost.
Without "Boost fooling" software the factory computer would throw an overboost code and possibly pull back fuel.
With my setup I hit about 32psi pulling a hill at WOT.
Old Dec 10, 2008 | 01:25 PM
buralcat's Avatar
so with the elbow i would need the fooler then in order not to get defueled, or does your edge do the trick
Old Dec 10, 2008 | 06:08 PM
cLAYH's Avatar
My edge takes care of it.
Old Dec 11, 2008 | 07:51 AM
buralcat's Avatar
thanks for the help guys, just ordered the elbow. if anyone knows of an 04.5 turbo out there let me know. thanks again
Old Dec 11, 2008 | 01:32 PM
cLAYH's Avatar
Did you buy your truck with the juice already on it? On the Edge for my '01 it came with a boost elbow in the box. Might want to check if your turbo already has one on it.
It will look like a brass 90* fitting.
Old Dec 11, 2008 | 10:42 PM
modjunkie's Avatar
How dependable is the boost gauge on the edge att. I get all kinds of different boost numbers. I can be going down the road at half throttle and be boosting 21-23 let off and stand it full throttle and wont boost over 18. It acts like its not boosting as hard but think that it might be just the gauge is wrong. Anybody have any ideas or is this normal. Was going to look for leaks but it shouldnt boost this high if i had a leak.
06 megacab, edge att, 5" magnaflow, leveling kit, 295/70-17 toyo mt
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
