Boost question
Old May 15, 2006 | 08:34 PM
LaneFarms's Avatar
Question Boost question
I just installed my Edge juice today and took it for a test run. When I got home I noticed that the check engine light was on. I ran the scan for trouble codes and it came back with low boost. Do I have something hooked up wrong or is there another problem.
Old May 16, 2006 | 07:19 AM
MikeyB's Avatar
First thing to check is all the electrical connections. It's a good idea to add dielectric grease to the pins before installing.
MikeyB
Old May 16, 2006 | 10:36 AM
Dan Marino's Avatar
I got the same code along with rail rpessure sensor high 0193. Mine went away after 5 starts but it showed up again when i got an 0133 intake temp high after pulling. It went away again. I have had some other codes from trying to use higher levels before operating temp of 174*. A word of advice -dont try them untill 174*at least -my truck shut completly off once -I called edge and the tech reinforced the 174* rule several times to me. My truck runs fine so I figure the codes it triggers arent bad -yet
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
