Anyone dyno a 03/04 305/555 w/ Smarty and a HTB2 62/12
From: Used to be missoula, montana: Now in Sonoma County California
Just curious wondering what you got for results.
Specifically on a 03/04 305/555 running just a Smarty using either the
Smarty S-06A Ver. 4.09B, Data: 2.08A or
Smarty S-06A Ver. 4.09B, Data: 2.08B
or
Smarty S-06A Ver. 4.09B, Data: 3.08B
just about sold on the idea of Hanging a HTB2/12 off the truck, ive inquired with a handful of people over the last few months on thier results and pretty much leaning towards the 62/12 but thought it would be fun to hear what some have gotten to the wheels with this combo.
Towing a 12-16k lbs gooseneck from sea level to 12k ft tends to warm up the stock turbo pretty well withthe smarty on 7 and even on 5 many times over 6k ft plus its just the fun factor
or
Can't really help directly but I can say that with smarty it doesn't have to be an HO for those years. The Smarty brings the SO to the HO levels. It is just an ECM thing from what I understand. (meaning there is a chance I could be wrong
I've just installed twins and the bottom turbo is a BHT3B. As soon as I can get to the dyno I'll post results.
)I've just installed twins and the bottom turbo is a BHT3B. As soon as I can get to the dyno I'll post results.
I had twins on my last truck i loved them.... like you should love twins
HX35 hybrid top/ S400 bottom towed like a dream
i thought the SO trucks had a different compression ratio guess not lol 17.2:1 across the board
for some reason i thought his was running a predator and a puck or something like that. i liked his thread about the turbo after he first put it on he along with a few other postings definately sold me ont he idea
His dyno numbers definately give a good idea what is possible, i thought maybe that the smarty with the specific tuning for the after market turbo on stock (IIRC 4 hole 03/04) injectors might yeild some higher numbers??
Thanx for the heads up
I have that turbo now and also ran it on my 03. I was running a TST/EZ when I made those numbers and that was in the SO. A similar HO made about 20 more hp and 50 more tq. If you stack something with that Smarty I think you will surpass those numbers I put down....
62/12
I would recommend getting the 62/14 instead of the 62/12, and even then I don't think it's going to help towing that much weight at that kind of HP.(SW 7) I have an II PS62/14 and with the 100 Horse injectors I had to remove the Smarty altogether when towing my travel trailer last month. It just does not cool enough.
As for the HP rating on the Dyno my Smarty/Quad stack did 439/892. The 03-04 are at a 40 HP disadvantage from the 04.5+ trucks with the Smarty.
or
or
556.8 with Smarty Bata 4.3 on 9
602.31 TST on 2 and smarty 4.3 on 9
627.49 same as above but water/meth 33% meth
Turned a best 1/4 of 13.05 at 107.4 mph with above setup
ModManiac
65
Feb 12, 2008 07:39 AM
ddestruel
Feb 7, 2008 08:11 AM
Xonid
May 29, 2007 08:02 PM
tcr
28
Mar 31, 2007 02:19 AM
metal_miner
Aug 9, 2005 07:42 PM
