once high idle is installed
Old Feb 5, 2008 | 10:03 PM
Teamropinram85's Avatar
Cool once high idle is installed
once the dealership installs the high idle how do I engage the high idle ? What are the benefits of havin this program and should I need this in south Texas ? Thanks Marko
P.S. I found the sweet spot for mpg in 6 gear 65mph I'm getting 17.5 most I've seen I'm not sure if the truck console is accurate but if soo that sweet for a 6.7!!!!!
Old Feb 6, 2008 | 04:48 AM
sabersix's Avatar
To engage high idle, put the truck in park (or equivalent for manual). Turn on the cruise control and then press "Set". RPM will jump to 1100. Use the right-side cruise buttons to raise the high idle up to max 1500. High idle disengages when the brake is pressed.
Note: Turn on the EB to warm the engine more quickly.
Old Feb 6, 2008 | 07:15 AM
mastercaster's Avatar
did you ground the proper wire too?
here is a cut and paste from one of my other posts. you don't need any extra parts for the high idle on the manual tranny. just do what i stated below and it will work.
"i have written about it many times on several sites. here are instructions and a link....
you don't need any extra parts to enable the high idle on a manual trans!! i did mine and have posted how to do it before (on other forums). you need to have the dealer enable it, just like on the auto trans. the only other step is to ground the one wire. the wire is located on the firewall. driver side, far left bottom firewall. basically if you go staight back from the emergency brake handle to the firewall, you'll see a large wire harness, white in color. you can unhook that harness, and behind it there is a very short (4 inches maybe) dark green wire coming through the firewall. the wire has a heatshrink cap on the end. strip the end of the wire and ground it to one of the two bolts next to the harness. that's it! let me know if you need more info. you'll need your flashlight to see that little wire back there. that's it folks no money on any parts. that wire is for the optional clutch safety switch. it is really not needed, as the transmission has to be in neutral and the emergency brake set, in order for the high idle to activate. if you touch the brake pedal, release the emergency brake or put it in gear, the high idle will disengage."
https://www.dieseltruckresource.com/d...d.php?t=165798
Old Feb 6, 2008 | 07:43 AM
w.tx iceman's Avatar
Is this wire on an 05 also
Old Feb 6, 2008 | 09:03 AM
White Fury's Avatar
If you are going to be Idle for a while go ahead and kick it up to 1100 RPM. They say that is actually more fuel efficent because of proper fuel burn than just sitting at idle.
QUOTE=Teamropinram85;1930660
"Note: Turn on the EB to warm the engine more quickly"
Warm up is way quicker with the EB on and High Idle active.
Old Feb 6, 2008 | 09:08 AM
i am pretty certain on the 5.9 you have to ground port #22 on the ecm, then have the dealer turn on the high idle feature. easy enough to do. try a search on here for it.
Old Feb 6, 2008 | 07:54 PM
FATCAT's Avatar
Your link doesn't work.
Do you have any pictures? I'm a visual guy.
Thanks.
Old Feb 6, 2008 | 09:05 PM
try this link. it is just to one of the threads about the high idle in which i posted what was above. i didn't take any pictures. it is really much easier than it sounds. you can have that wire grounded in 10-15 minutes. then just ge tthe dealer to enable the feature.
https://www.dieseltruckresource.com/...=165798&page=2
Idaho Guy
22
Jul 23, 2014 11:48 AM
robert78.5
Nov 10, 2013 06:33 PM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
